Acer monitor come up no signal will not boot up on start
Check the cable at the back of the monitor and at the back of the computer. If the cables are in tight and you still get the no signal error message you either have a bad monitor or a bad video card in the computer.
Try plugging another monitor into the computer (borrow one from a friend, neighbor or family member if you don't have one). If the monitor does the same thing and shows a no signal message like your original monitor, then the Video Card in the computer is bad. If the monitors works, then your original monitor is bad.
SOURCE: Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
SOURCE: my acer aspire m1640 crashed and now when i turn
Sound like a bad motherboard.You are getting the error because no signal is been sent to the monitor. Make sure the memory is inserted properly and firmly. Check all other cards and plugs are all inserted and firmly sitted. and try to boot the system, if nothing stll happen, you may have a bad motherboard
SOURCE: Acer Aspire M1640 has no signal to monitor ? I try
I have the same problem, i have tried everything and some people say its because the graphics chip on the motherboard has burnt out due to improper cpu pasting
SOURCE: Acer Monitor V193W has no signal
There are 2 basic reasons for the "No Signal" message.
If neither of these is the case, try hooking up a different monitor (if equipped, you can use an HDMI cable to your TV) to see if the "No Signal" message persists.If using a different monitor works, the issue is your Acer Monitor.
