Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
C4180 Won't Power On
I have an HP C4180, less than 2 years old, worked fine and was quite pleased, but now it won't power on. We haven't had any electrical storms or power surges (and the printer is plugged into a power surge).
When I press the power button, no action and no lights. When I unplug the unit and plug it back in, the power button blinks orange twice as soon as it plugs in and the flashes occur quickly.
I tried a suggestion of unplugging from the surge protector and trying other non-surge protected outlets, and those have not worked.
Any help is greatly appreciated.
Paul
    President:
  • 1,901 Answers
Make sure the plug is all the way into the AC adapter. Then, you will need someone to verify the output of the AC adapter. You should have a 16VDC and a 32VDC output from the adapter. If that is good, you have an internal problem with the printer. If the output voltage(s) are missing you will need to replace the AC adapter.
Here are the specs:
  • Input voltage: AC 100 to 240 V ~ 1 A 50–60 Hz, grounded
  • Output voltage: DC 32 Vdc===940 mA, 16 V===625 mA
  • HP part# 0957-2146 Call 1-800-227-8164 for availability.
  • Posted on Nov 19, 2008
    • Daphnie Ann Penetrante Sep 28, 2013
      is it safe to plug my c4480 to extension cords??
    My tv won't turn on
    replace the power supply board @www.shopjimmy .com
    Mar 09, 2013 | Televison & Video
    ASUS K54C won't power from battery
    Take it back to shop if it's only 2 weeks old
    May 06, 2017 | ASUS Computers & Internet
    How do I find the security code for my Matsui VP 9606 VHS Player
    Try this
    Unplug from wall for 30 minutes, then plug it in again. Power it on, and then PRESS CH UP & REC/QTR BUTTONS TOGETHER on your machine ~ (haven't tried it via the remote) Should then come up as "Pin OK" on the blue screen
    I don't think it will give problems after that. Should stay unless you unplug for 30 minutes, the buttons won't reset the video.
    Nov 17, 2011 | Video Cameras
    It'll turn on and run but it flickers the entire time. its happened before but quits after a while. this time though, it won't stop. any suggestions?
    Best bet would be to unplug it completely and let it sit for about five minutes, plug it back in and turn it on, if it's still flickering there's more than likely something wrong with the backlight or the power supply. All Insignia TV's carry a 2 year manufactures warranty, so if it's less than two years old just take it to a Best Buy and have it serviced. It'll be gone for a few weeks, but either issue is an expensive fix.
    Aug 27, 2011 | Insignia NS-LCD37 37 in. LCD TV
    I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
    Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
    Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
    I have a Toshiba 26AV502R tv, was working yesterday and now it won't turn on? It's about a year old. What do I do to fix this?
    the only thing you can try to do: unplug TV, let it "reset" for a minute or so, then plug it back in. If that won't help, means: surrender to repair service. for 1 year, even with 24/7 usage, there is a slim chance for "bloated" capacitors inside of TV's power supply, but quite a good chance of your main board failure. Now a days they quite compact, packed with high temperature producing IC chips, led-free solder, which has drawback of "fatigue" failure. Or, there might be power surge involved. In any case, except "lock up", appeal to TV repair service.
    good luck,
    Alex's Television,
    215-806-5980.
    Jul 16, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
    I just had a power outage and now my HP 4104gl procurve switch will not power back on.
    I hope that you've gotten this problem resolved by now... but if you haven't, it sounds like you have a blown power supply. You can contact HP at 1-866-my-procurve. Use caution as to how you tell you it died or they won't help you with this problem.
    They may be able to ship you replacement power supply or switch.
    Dec 29, 2010 | HP ProCurve 4104gl Networking Switch
    HP PhotoSmart C4180 All-in-One... Problem:
    Try the resetting the printer to factory defaults.
    Steps:
    1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
    2.Then, Press and hold the ON button for 30 -60 seconds
    3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    Please let me know, the status. GoodLuck cheers!!
    Thank you ...
    Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
    HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
    451 people viewed this question
    Ben Johnson
