Question about GE DBXR463GB Gas Dryer
Front felt drum seal on ge came off---hard to repair?
Front felt seal has come off the front of the drum. Is this a hard fix?? Ge electric dryer ..2yrs old
  • Anonymous Dec 29, 2008
    What do you mean take the front off? From the inside of the dryer or from the outside of the dryer?
  • aweik Mar 01, 2009
    I have the same issue. Where does the felt gasket actually go inside??
  • 4 Answers
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Posted on Nov 23, 2009
    Sergeant:
    Champion:
  • 324 Answers
No its not hard, just unplug first and then just take the front off and take note where the wires go to the door switch.,also check your drum to make sure you did not damage.
Posted on Nov 19, 2008
How do I get the front panel off a ge mod djsr473et6ww cloths dryer.
GE Dryer Repair - How to Take Apart, Open, or Disassemble ...
? 6:21
https://www.youtube.com/watch?v=AgsOwIwoygc
Feb 22, 2013 - Uploaded by canyonman1963
Tags: GE, General Electric, Frigidaire, Electrolux, electric, dryer, open, remove, take apart ...
Dryer Repair - Replacing the Lower Front Drum Felt Seal ...
? 9:42
https://www.youtube.com/watch?v=XoYP_YsGP68
Jun 7, 2011 - Uploaded by PartSelect
Dryer Repair - Replacing the Lower Front Drum Felt Seal (GE Part .... on this dryer....how do you remove the ...
Nov 03, 2015 | GE Dryers
GE Dryer DBVH512EF0WW vibrates/shudders excessively. Particularly with the top on. I've replaced the front top bearing, drum slides and felt seal. What is my problem?
The only thing I can think of is if you have plastic inserts built into the drum then maybe you installed the wrong kit in the dryer.
Their are basically 2 styles of GE dryers. Those that have a steel drum and a bearing with glides on the front panel and those that have felt on the front panel and the plastic glides mounted in the drum itself.
Oct 12, 2012 | GE DCVH515EFWW Electric Dryer
GE DPSR483EA Electric Dryer was making a scraping sound when operating, now a felt like belt has come out on the inside of the dryer. what do i do? Kris Long
The problem is something got between the drum and the felt seal between the drum and the front of the machine. You will have to pull the front off and find out what caused the felt to come out and then put the felt back in place and put the front back on.
Mar 18, 2010 | GE DPSR483EA Electric Dryer
I have a GE profile Dryer DPSE810GOT and the dryer sounds like its running on metal to metal is the felt around the drum one piece or two and counld that cause it
The felt is two pieces. And, no, the problem is the drum support glides have worn through, allowing the drum to continue to wear into the front drum bearing. Replace the front drum bearing (WE3M26) and the drum slides (WE1M481) located at the top front of the drum.
Feb 28, 2010 | GE DPSE810EGWT Electric Dryer
The dryer squeals (metallic sound) while drying clothes.
check wear pads around front of drum or rear depending on brand. Ge's are particularly prone to scraping sounds, but still one of my preferred brands. IF a ge, did it get any dents around the sides or back? The drum is close to the sides and a dent in right place will do it. Also the rear panel can push the drum forward rubbing in front.
Ge - wear strips in front, plastic bearing in rear center, replace both, inexpensive.
Whirlpool- felt pad and wear strip in front, felt seal in rear with roller support. check rear seal lube rollers
Maytag -roller in front and rear with front and rear felt seals. some designs have front drum support posts with wear pads. ck these.
Frigidaire (include some sold under GE name) rear bearing cup (plastic)-lube, front feltpad with wear plates if plates gone get new pad/wearplate asm.
Maytag and ge nomenclature tags are in rear .
Jul 19, 2009 | Dryers
Drum seal came out
I assumed there was a gasket on the top but there are 4 drum slides or glides on the top.They have worn out. I have to replace the top drum bearing piece(plastic, so it was wearing down)and install 4 drum slides(they are extra).Drum seal on bottom was ok.Ordered parts from appliance parts pros.com, they were 33% cheaper than manufacturer(GE).
Mar 22, 2009 | GE Profile DPSB620ECWW Electric Dryer
Dpsr475gw0ww GE Profile Gas Dryer noisy
The felt seal should be replaced if it is bunching up. The squeak could be due to worn drum rollers in the rear.
Jan 07, 2018 | GE Profile DPSR475GW Dryer
GE Spacemaker dryer scraping metalic sound when on
i know you say ge dryer but i think thats a frigadire inside ge dosent make an over under.When dryer off take your hand and go around the in side of the tub where it meets the felt seal.some times somthimes somthing will get caught between the turning drum and the felt seal causing a noise.if not that you have some wear problems and will have to take apart to inspect
Dec 31, 2008 | GE Spacemaker Washer and Dryer Electric...
GE DBXR463GB Gas Dryer Logo
1,079 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
