Question about Whirlpool LGR7646E Dryer
Whirlpool LGR7646EQ0 turns no heat
I can not find how to get the pilot light re-lit. And I don't know if it is the burner, or the ignitor that has gone bad. I have stuck a flame all around and nothing ignites, or lights.
Thank you!
  • 2 more comments
  • jason_heien Nov 19, 2008
    I have already checked the vent (from the lint trap to outside, and it is aok. I will check the power on the ignitor, and get back to you.
    Thank you so much!!!
  • jhoneill_200 Feb 03, 2009
    Same problem here. Where do I get to ignitor? Took off the back but now sure where to go from here
  • jerms27 Feb 22, 2009
    Same problem as well. Now taking the dryer apart to find the ignitor. I have the back panel off and will soon be taking more of the dryer apart. I'll let you know if I find it!
  • DanKramer Mar 23, 2009
    I also have the same problem. Does anybody know if changing the thermal fuse (plastic part with two blue wires attached) is a troubleshooting option?
    Problem Solver:
  • 7 Answers
The dryer has no pilot light, haven't had them in years. It operates off a hot surface ignitor.I would check to see if you are getting power to the ignitor 115v. If you are the ignitor is bad. Sometimes you can see the ignitor cracked. Did it take long to dry the clothes before it quit? If so your vent may be clogged which will blow a thermal limit on the dryer and keep it from heating. hope this helps...
Posted on Nov 19, 2008
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
I am a new homeowner. I have an H400IDLunit that is a pool/spa combo. The code reads "00" in the heater window and does not change when the unit controlls are pressed. I have an aqualink...
I don't know if there is a pilot light, spark ignitor or thermal ignitor. I would determine by inspection what kind it has. If you open the front cover you will find a gas valve. It can be identified by following the gas pipe that enters the side of the heater and attaches to the gas valve. If the valve has a control knob on it that has an off, on and pilot position then it is a pilot type. If this control is not on the valve then the unit includes an automatic ignitor.
To light a pilot equipped system place the knob in the pilot position, push it down, and use a flame to light the pilot. If you hear gas flowing from the pilot but it won't light then there is air in the line and it needs to be purged. Holding the pilot lighting valve down long enough will purge it but may take a long time. Periodically you can check it by trying to light it. If it lights watch it for a while before trying to turn the heater on to make sure it is fully purged. Once the pilot is stable and the thermocouple is heated the pilot valve can be released and it should stay lit. If not, try again.
Don't get down and look into the burners while you are trying to start the system because it could flame out and burn your face. If you turn on the heater again then the gas valve should come on and the burner should light. You can usually hear a loud snap when the gas valve come on. You should then hear the gas flow to the burner. If the burner doesn't light you should be able to smell the gas. If it lights exhaust will be coming out of the vents in the top of the heater.
I am sure you will have more questions so please respond with them. I hope this helps.
Sep 04, 2011 | Hayward H-series Electronic Gas Pool...
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
I have an old Kenmore 70 Series dryer, just this weekend, the drum turns but no heat..... after a little search online, I suspect the pilot light went out. Where is the pilot light located? I lost the...
The burner is on the lower right side of the bottom under the drum. See this manual pdf page 23 for location and access. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The burner uses an ignitor and a flame sensor vs a pilot light. See this link pages 12 - 14
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/c5c81d2c8f26b1b5852574f20055c20c/$FILE/4314010.pdf Note the M series burner has been in use since 1984.
The dryer must have a complete termperature circuit and no "high temp limit" failures for the ignitor to light. That means the door is closed, motor is running, and the cycle thermostat is less than 135 deg F and the High limit thermostat is less than 180 deg F just to provide power to the gas valve solenoids, ignitor, and radiant / flame sensor.
Thanks for choosing FixYa,
Kelly
Nov 28, 2010 | Dryers
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
I have a sv9500m 2674 tha has a sticker that says it has been converted to L P gas. The ignitor lights the pilot and the fan comes on. The pilot stays lit and the main furnace fan comes on but the burner...
Hello,If you cleaned the flame sensor and it is in the pilot flame,Try adding a ground wire from the pilot assembly to any close screw to boost the (pilot on) signal.Also if the valve has been sitting for a while give a tap once during (pilot on) to make sure the diaphram is just not hung up.I would hate to replace the valve and still have the same problem.
Oct 15, 2010 | Honeywell Heating & Cooling
Drum turns but no Heat problem!!
Brian, if the glow ignitor comes on for a minute clicks and goes off then you need valve coils. if no glow at all could be ignitor or thermal fuse.
Jun 27, 2010 | Whirlpool LGR7646E Dryer
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Dryers Logo
    599 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
