Question about Lexmark Office Equipment & Supplies
Dont know how to replace ink cartrige - Lexmark Office Equipment & Supplies
    Genius:
  • 1,124 Answers
The print must be ON. Open the cover of the printer and after that the print cartridges automatically will move to the front. See the diagram inside the printer to see the right position of the cartridges. Remove the old ones and insert the new ones but first you have to remove the sticker of the head print (usually a tape). If you need more help let me know which is the model of your printer and i will give you accurate instructions.
Posted on Nov 19, 2008
When i print pictures, the pictures print shuters and i dont know how to fix it
  1. Check the ink cartrige or toner cassette, because the problem could be caused by lack of toner or ink.
  2. If your printer is InkJet - some of the color cartrige's nozzle could be clogged. You can choose to buy new one or to put the cartrige in warm watter to unclog the nozzle, but you have to be careful.
  3. Try to change DPI and check if there is a difference between the copies.
Dec 02, 2011 | Epson Office Equipment & Supplies
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
The other day i opened the cartriges to see the number so i know which ones to get at the store and now i know ink is very low not sure how low but when i try to print it says allign cartriges and it dont...
Hello. Usually, the printer will just notify you that the ink levels of your cartridges are low and if they're out of ink already, it will advise you to replace the cartridges and won't print. In your case, the cartridges may be sending wrong information to the printer. Since the ink levels of your ink cartridges are low already, you might as well replace them. Hope this helps.
Mar 21, 2010 | Lexmark X2600 InkJet Printer
Ink cartrige cannot be recognised
make sure you've taken the protective tape off the cartrige. Usually its orange and noticeable.
Sometimes generic cartriges have a small chip and a registration that allows the printer to talk between the cartrige from what I under stand maybe ink levels and to protect profits on not allowing generic companies to make a more economical product competitively
the printer can sometimes be power cycled to allow it to accept the generic cartrige.
there are normally settings on a printer to see if you can change the internal settings can be altered to allow non Original Electronic Manufacturors products in a Canon Printer.
make sure that the type of printer you have is compatible with the printer. the computer may require a black cartridge or a color cartrige in a very specific location. they might not be allowed to be switched.
make sure the cartrige can slide in and out of it's slot comfortably.
FOR office printers. there are also protective tabs holding the ink in the cartrige. this side tab on the cartrige is there for shipping. these are normally on large 30 pound printers. top front loading Office printers. the tab needs to be turned hard and swift either clockwise or counter clockwise if you can't cleaning pull it out. Also remember your boss paid a lot for that cartrige dont break something your not comfortable breaking. be warned in advance this dry ink will spill and is hard to clean and harder to clean from clothing.
as per a fast solution a smaller printer and certainly a cartrige can actually be brought into a computer and electronics store whilst looking to buy a new print cartrige. Make sure if you do bring a piece of your own electronics into a store you check in with security. let them know its yours; wave it in front of a camera if youd like.
the seller normally should be able to recognize if their product will fit in your device it will save both of you time and inconvience.
cartriges cost about the same as a new printer with new ink.
dont be afriad to buy an extra ink at the time of purchase and risk letting it dry but having the back up that you know works-
you'll have a package for the next time you need a new cartidge. gives you more research material.
accept moores law
feel good about flossing on a new printer.
print some pictures and frame them-
pictures are some of the most important thing in our lives! Smile!
Mar 10, 2010 | Canon Office Equipment & Supplies
Canon MP 610 printer. Cartridges half full when forced to replace
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
Jan 16, 2010 | Office Equipment & Supplies
Don't acept cartrige of ink. Allthe time the
this happens when you insert fake cartridges in HP. usually i think higher products of HP dont accept fake cartridges.
Go for vivera inks. they are genuine HP inks.
or look out for pin in the cartridge area. as it may not be settled properly
Dec 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer dont print without one of color ink
u should use all cartrige for printing with your printer
Apr 24, 2009 | Office Equipment & Supplies
The printers fine, but something is wong with the ink cartriges
Hmm, you need to specify the indicator to get more help. Never mind, I recommend you to visit Canon Inkjet Printer Forum and find this article: How to identify error indicator. Then you will know your problem ok. You may repost your problem later if you need more answer from me.
Regards,
Nov 24, 2008 | Canon PIXMA iP1600 Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
