Question about Kenmore Elite 45986 Front Load Washer
Pump on kenmore elite not pumping water to drain
I did clean out the trap and everything but pump sounds like it is running but it is not pumping water out
    Genius:
  • 1,028 Answers
Possible pump impeller may be loose on motor shaft also be sure tank to pump line is clear and pump to drain is clear
Posted on Nov 19, 2008
Where is the coin catcher on a Kenmore Elite H3 washer
it is most likely the pump. you can remove the pump and debris trap easily, separate the pump from the debris trap by depressing a tab and turning the pump clockwise from the debris trap. the pump is a mag drive unit and is easily dis-assembled. ours had debris inside the pump, once taken apart there was some black colored fine sand inside that once cleaned out the pump returned to normal function. we bought a new pump but the old one still works since it was cleaned out, the rubber o ring had leaked letting the debris inside the impeller assembly. hope this helps out. it worked for ours
Dec 03, 2017 | Kenmore Washing Machines
The spin cycle is not draining, what are possible reasons?
clean or replace your drain pump. if you hear your pump running you need to clean out the button trap of your pump.
Apr 29, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine not empyting all the way during the rinse cycle? the machine washes fine but not empyting all the water during the rinse cycle?
Does it go into high speed spin? If it does and there is still water than check to see if the filter or hoses are clogged. The hoses the run from your basket to the pump and the drain hose too. A washer is only given so much time to drain all the water. Most of the time the filter or coin trap hose is clogged. If everything is clear u may have a weak pump.
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite error message F 02
Here is what the manufacture says about F02 - Below this are my comments
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments---->
If you washed a rug with a rubber backing or small articles like baby socks you may have a plugged up pump. To access the pump lay on the floor and remove the 3 screws holding the lower panel of washer on. Pull down and out on the panel to remove. Lay out a lot of towels under the unit, I mean a lot... Look in the center for a white cap about the diameter of a large cup, it will have a handle on it to turn, turn this left(counter clockwise) to unscrew. This will unscrew and pull out, but be careful when it comes out so does all the water. Clean out the trap that is in your hand and anything you see or feel in the sump area the trap came from. Reassemble and test. If this does not work you will more than likely need a new drain pump, that is the component on the right of that trap you just cleaned out.
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
Need to know how to clean lint trap and where is lint trap located on the Kenmore He3 washer
The only trap on a Kenmore Elite HE3 is in the drain pump. The following link explains how to access and clean it out:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provided and let me know if you have any questions. I personally own one of these washers and have repaired them many times. If you are experiencing drain problems, the problem will most commonly be attributed to the drain pump trap becoming clogged with debris. There's usually an error code associated with this problem of "F02". If you attempt to clean the drain pump and you discover the pump to be clear, check the drain lines (especially the line running from the bottom of the wash tub to the inlet side of the pump). If all these preliminary checks don't solve the problem, the manufacturer recommends replacing the drain pump.
If this is not what you were talking about, please post back and elaborate a bit more so I can understand the problem you are having. I hope this helps you.
Jun 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
F02 error on Kenmore front load, followed solution, problem still exist, What next?
cant see what you tried to repair problem (dont see original post) but F02 is a long drain time. or innaddaquate drain. usually from a clogged, drain pump/button trap. ill assume you were told to remove the lower access panel, gain acess to the drain pump assy, clean the "button trap" of foreign derbis. if thats been done and your still having draining issues iehter theres something i nthe drain hose, or perhaps the drain pump impeller has been damaged preventing proper flow of water.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2
Yes, it will. There are two screws holding the bottom panel in place that you will need to remove first. Your pump may be constructed differently than the full size HE models. If you do not have a clean out trap, unplug the washer and remove the pump. Flush it with water to clean out the impeller. DO NOT submerge the motor portion in water, however. If you have to remove the pump, just disconnect the electrical connections and the inlet and drain hoses. DO NOT remove the hose from the bottom of the wash tub. Disconnect all hoses from the pump only. In my past experience, this particular hose is a real bear to get back on. You may not have to do all this. I include these instructions, however, because some of the small front loaders do not have a clean out trap on the drain pump. I hope this helps you. Let me know if you have further questions.
Sep 03, 2008 | Washing Machines
Water not draining.
You will need to remove the front lower axcess panel. There are 3 torx or 7mm Machine screws securing the bottom of the panel. Once the panel is removed you have axcess to the trap. Its the large plastic screw cap. Be ready to catch some water with a shop vac or other means.
Nov 24, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
181 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
