Question about Malber WD1000 Front Load Washer/Dryer
Soapy water discharge
This seems to happen if too much soap is added to the cycle; I'm not 100% sure. Even if so why the disharge from below the unit? The discharge hose is attached properly.
Thanks.
  • gogio2008 Nov 19, 2008
    Thank you oldfixer. I'll give HE detergents a shot.
    Genius:
  • 1,028 Answers
All front loads need HE detergents ..high efficency low suds ..excess suds have been known to come out through tub vent line
Posted on Nov 19, 2008
Hi - my washer keeps displaying the f35 code and stops - i then cant unlock or cancel i have to unplug it - seems as though there are no repairman who know what this is - can you tell me what i should do...
The F-35 on some models means:
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
Under $100
Item 20
W10156252
May 02, 2011 | Washing Machines
The water is still soapy after many rinses. I am using very little soap
I am having the identical problem with a Maytag washer! The first 2 or 3 rinses are effective somewhat, (but not like the Whirlpool I had for 22 years) and I think, "one more for fabric softener"---but suddenly I have a full inch of bubbly white, white, very soapy suds! Picture half a washer of water with a cup of tide! It's that soapy and I cannot figure out where the soap is coming from! Tonight, I had not even used a regular soapy detergent in the previous 15 cycles, having switched to an eco detergent from Costco and used little. I even ran a few cycles with no laundry and no detergent--no soap then!
Btw, the washer has only cold water rinses--I had not noticed the tiny print on the front of the washer--or I'd never have bought it. We learned in fabric class that icy cold water (it's snow melt here in Oregon) shocks fabric as badly as hot water, and it fails to get soap out as well. And everything comes out scratchy stiff like cardboard, and hurts my face--skin even peeled before I began opening lid to check on rinse cycle. I got rashes and dry skin from all the soap and ice water...until I began doing 7 or 8 rinse cycles on the items like washclothes, towels etc. Clothing gets hardly any soap, or I hand wash it now--am exhausted and want new machine! Can't sell this junk tho.
Anyway, so the way I rinse with warm or cool (not melted snow) water is I stop the washer and start over the wash cycle to get warmer water for the rinse. Then, I move the dial to extra rinse cycle for the rest of the rinse, after the water has filled, so it cannot go on to do an ice water rinse after competing the "wash" cycle that's really a rinse cycle with no soap.
I would hurt the person who designed this washer! It seems to add soapy water back into the rinse on the 4th rinse cycle! Sounds bizarre, but I always think that everything is finally rinsed ok and one more with a little fabric softener will do it, but when I look inside to add the downey, there's an inch of suds on top! I don't have suds like that on my wash cycles! It's bizarre...I've wondered if neighbor's suds are coming in, or am I haunted?
Last week, I hand-rinsed my washcloths and kitchen towels and put them in washer for the spin cycle, at end of the rinse cycle, just to get water out of them for dryer.... To my dismay, the spray of water while spinning (have no idea why washers add icy snow melt to my warm rinsed laundry during the final spin but they all do, you can hear the spray) was soapier than my original wash cycle--which has a teensy bit of suds which is gone in a minute or 2! Honestly, my washcloths etc were fully soapy again! I'd rinsed them so well that immersing them in warm water left the water clear and clean, but after the spray, they were just as soapy as after the earlier rinse cycles that had the inch of suds... I had to take everything out and spend another hour hand rinsing and wringing befor the dryer....
I have taken to using pint-sized tupperware to get the suds off the top rather than letting it go into the laundry or washer. I skim it out and put it down the kitchen sink. It's so soapy I'd have to do dozens of rinse cycles to rinse it out, so I skim it out manually. So new soap must keep getting into the washer! It also does not seem to matter whether the wash is full or half. Tonight the previous rinse cycle had been full, and pretty clean. But when I o;pened the next one to add fabric softener, it was only half full of water, and an inch or soap suds. I had wondered if the soap was outside the basket, and came in through the holes, once water got that high, but no. Does not matter. And I had wondered if it was caused by suction from stopping the rinse cycle during spin...but I went load after load for 10 days, never stopping a cycle early and it still put all that soap in the 4th rinse cycle. Or in the 3 cycle's spin at the end of rinse, when it sprays water on the spinning laundry.... This is a horror. Maytag ignores my emails. The handyman says new washers are terrible and wants nothing to do with it. I wish I'd paid whatever it took to fix my old whirlpool. 22 years and never an issue ever, never more than 3 rinses and then only a 3d because I'd used double soap to get out dirt from gardening or road trips like Santa Fe in the winter when shih tzus got covered with red clay dirt used on snow and ice--that stuff is lethal! Normally I added fabric softener on 2d rinse cycle and things were so clean. Now things are not clean, come out ripped, or with pilling like they aged 10 years in one night. So I handwash anything I want to keep nice. Washcloths are getting frayed, towels look bleached or faded....and I am relating to my grandmothers on wash day. Sorry it's just more problems not solutions.
Jan 23, 2011 | Kenmore Washing Machines
We have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Maytag Neptune filling with water
Is this happening after it has not been used for a while. If so you have a fill valve slowly bleeding some water in. Almost like a dripping faucet. The only way to fix it is to replace the valve. If you want to check it turn the breaker off to the unit when not in use to see if if still fills up. If so you know it would have to be the valve.
Apr 18, 2008 | Washing Machines
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
HElp Dishes not coming clean
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
47 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
