GE 19GT270 19" TV
Problem for GE 19GT270 19" TV
Horizonal White Line
By maverick1955 on Dec 25, 2006
Set was working fine then turned it on and all I recieved was a horizonal white line across the center of the picture.
After a few minutes the picture would appear.
Any ideas with part numbers and appox cost to fix
Best Solution
posted on Dec 25, 2006
Helpful)
techman
Rank: Guru  GE Expert
Rating: 86%, 7643 votes
Your problem could be one of the common ones as this set has loads of bad solder connections. Your problem is most likly the verticle output IC connections or the B+ feed componets have bad solder connection on them. In some cases though the Output IC is defective and will need to be repalce. if you have no soldid state repair or soldering skills play it safe and get a pro to assist you in this repair. It should not cost you more then a hundred bucks or so and thats the high end. good Luck, And Merry christmas.
Was this helpful?
Yes
No
Popular Solutions for GE 19GT270 19" TV
Questions and Unsolved Problems for GE 19GT270 19" TV
Do you recommend GE 19GT270 19" TV?
Answer
Answer
How do i get the TV unlocked
Answer
need the code for t/v model Ge 19GT270 to use a universal remote
Answer
i have a 19" 19GT270 and need to know the weight for mounting
Answer
I don't have a remote control for it. How do I change it to English, and get it to get all of my... (More)
Answer
I was recently given one of these TV from a motel who was replacing all their sets, it is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
