Question about Dryers
Inside of the dryer is turning blue - could it be the detergent?
  • happymommy26 Nov 19, 2008
    The inside of my dryer is turning blue as well, I assume it's from all the jeans being dried and the dye rubbing off?
    Problem Solver:
  • 7 Answers
Its dye from blue jeans, all you can do is replace the drum or ignore it. real common for whirlpool products.
Posted on Nov 19, 2008
How do I get the stuck detergent drawer open?
U see the blue colour softner drawr inside the detergent drawr just push it down after u remove ur drawr it will come easilly
Feb 25, 2015 | LG Tromm Front Load Washer And Dryer Set
I have turned off main gas line to dryer and have checked that and the connecting line to dryer and see no leakage but I still have an odor of gas in dryer itself. what should I check next?
check the line inside leading to the flame igniter and glo bar, how did u check for gas leak? just smell or sight? try using a mixture of water and dish detergent by spraying it on the lines while gas is on, and if u see bubbles u got gas leak?
Sep 05, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
Drum would not turn and there was a humming noise. Then the drum started to turn but throws blue sparks when it is turned on. These are inside the dryer. Not inside the drum. The belt is ok. It is not...
The is a wire rubbed through inside there...DO NOT use your dryer until you get the wires fixed!!! Turn off the power to the dryer at the circuit breaker and do not touch the dryer till all power is OFF!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jan 05, 2011 | Frigidaire FEQ1442ES Electric Dryer
Turning blue inside
Surely this could only be from your washing powder or conditioner. Is it blue by chance? If so, use less or change brands.
Mar 19, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Inside of dryer is turning blue. How do I clean it? My clothes do not seem to be affected by whites are staying white...but I can't figure out what to do about this.
My best guess, is it is your blue jeans. fingernail polish remover..non acetone usually does the job. Stay in a well ventillated area when doing this. Good luck.
Apr 20, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Detergent dispenser stuck
Had the same problem here today, the softener dispenser blue plastic piece was loose jamming the whole dispenser tray, to resolve remove top cover, two screws on top rear, slide the cover towards the back, you will then see the detergent dispenser, press the right clips and pull it off slightly at the back; do not put too much pressure and try to remove the cover completely, just pry the plastic cover a bit then pull the detergent tray it should come right out.
Apr 07, 2009 | LG WM-3677HW Front Load Washer / Dryer
Front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Mar 26, 2009 | LG WD-16115FD Front Load Washer
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Blue dye under three seperators inside dryer drum.
ok " you would have to pull the drum to get at those screws
what I would do is use a tooth brush with some bleach
that should take care of it.
Jan 23, 2008 | Dryers
Water is leaking out of detergent dispenser- big time
Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
Aug 24, 2007 | Haier XQG50-11 Front Load Washer / Dryer
Dryers Logo
111 people viewed this question
Top Dryers Experts
