Question about Kitchen Ranges
Defective Infinite burner control switch
Jenn-Air Electric Slide In Range Model JES8750AAW S/N 13747281AG - The detent function of the right front burner infinite control switch does not work and the switch is always on. The replacement switch does not have the same wiring terminals and the wiring schematic supplied with the replacement part is not the same as the original switch. Is there a cross reference for the terminals? I cannot get help from Jenn Air and a Maytag repair service tech could not figure it out and left.
Wire colors to the switch are as follows:
1 Red (Term 4)
2 Red (Term 5)
Black (to indicator light)
Tan (Term 2)
2 Black (Term3)
  • 1314 Answers
SOURCE: Infinite Switch Replacement
one switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Posted on Feb 18, 2008
  • 29 Answers
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
  • 189 Answers
SOURCE: Just replaced infinite switch part # 12002125 ...
Hello- First of all, congratulations on getting it out, apart, and back together again! There are two types of switches for this cooktop. One for the dual, other three are single. Wires can be a trick sometimes. Replacement switches look different sometimes, but work the same. If part is correct, check wire connections at contact points. Lightly crimp any loose ones. Partselect.com has the wiring diagram for JED8430.  Let me know if this info helps- have more if needed. - Thanks- ED
Posted on Mar 06, 2010
  • 6 Answers
SOURCE: Ancient (1971) Frigidaire Cookmaster electric
The stove has 4 burner switches with a # 2 terminal on each switch. This contact is similiar on all four switches. One of the switches # 2 contact is stuck. The burner switch should disconnect both legs of the 240 volt circuit, one leg through the # 2 terminal and one leg through the thermostat built into the burner switch. Disconnect the pilot lamp wire on each switch unti the light goes off and then replace that burner switch. This should correct the problem
phucks001@horrycountyschools.net
Posted on Jan 25, 2011
My large burner at the front does not work, yet when i replace it with\r\nthe large burner at the back it does not work , yet when you put the front burner at the back it works.
Your front burner is fine. Assuming you have an electric cooktop the problem is in the switch that controls that burner. The infinite control switch. Replace it.
Dec 07, 2010 | Jenn-Air Cooktops
My glass top with sealed burners Jenn-Air range is having trouble with the burners...the large burner does not come on at sall and the three smaller burners come on but do not maintsin the temperture...
Yes, you can fix this yourself! It is a simple repair thatyou canmake yourself, too.
The large burner needs to be replaced and the other burners need thr infinite swithces replaced on them.
I love the Jenn-Air brand ranges. Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will ship these parts to you overnight along with part removal/installation instructions for you to get cooking ASAP!
Thanks, Ella
Nov 16, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Top burner shorted out and now the indecator light stays on. and the burner will not heat.
Hi, It sounds like the infinite switch has shorted out. You will need to change the burner switch. Did you have the burner tested or replaced?
Make dure everything conected to that burner is ok before changing the burner switch.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 22, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Front right 8'' surface burner dose not light up period.
it could be your burner but most likely your infinite switch for that burner
Mar 21, 2009 | Kitchen Ranges
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Feb 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
119 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
