Question about Motorola Mobility SLVR L7 Cellular Phone
Removing faceplate??? how can i remove the face off of moto slvr? i cant seem to figure it out thanx ;)
  • 101 Answers
Hi. Have a look here http://www.formymobile.co.uk/l7disassembly.php
Posted on Nov 21, 2008
Can faceplate be removed from water tank
Did you figure out how to remove the faceplate? I am trying to do this to track down a leaking issue.
Dec 26, 2012 | DeLonghi ESAM6600 Espresso Machine
How do you remove the faceplate on a 2007 pt cruiser?
a lot of times there are screws behind the vents, the vents can be removed pretty easily to access them.
Sep 04, 2012 | 2007 Chrysler PT Cruiser
My motorola l7 was not responding after i was intall skin... when i turn on my phone it not responding and show white skrin and cant turn off
you might have removed the original Moto skin & the new skin that u installed may not be proper. download original Moto skin from modmymoto.com & install.
Always keep original moto skin. Never remove it..
Jul 13, 2009 | Motorola Mobility SLVR L7 Cellular Phone
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
My phone doesn't boot properly
Apr 25, 2009 | Motorola Mobility SLVR L7 Cellular Phone
I need help removing 97 sable headrests
at the base of the head rest there should be a tab that you can push in that allows you to remove them.
Apr 17, 2009 | 1997 Mercury Sable
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Feb 08, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Motorola L7
sory mam i cant figure out ur problem accurately
if u dont mind can u explain me ur problem on yahoo messenger
my yahoo id is funky_2_chunky@yahoo.co.in
Oct 01, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
