Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Blower moter runs on heater constantly
When heat is turned on heater does not have time to heat up because blower comes on
  • 57 Answers
Blower motor should not be keeping your heater from heating up. Something must be going on with your flame. Have you cleaned the heater recently? Is the igniter working? Is your burner ring in good condition? Maybe a sensor has gone bad? Trouble shooting at the rural energy website might be helpful.
Posted on Nov 30, 2008
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
I have a weather king furnace and the furnace runs all the time.
first check your high limit switch find the white wire coming from your blower moter and unplug it hold down your door switch to see if your furnace will shut off if not replace it and your blower will run for ten to 20 min or until your heater has cooled down.
Jan 04, 2013 | Heating & Cooling
Heater and ac not blowing at all
The first thing i would check is the heater blower motor for power.If the blower motor has power then pull and wiggle on the blower motor resistors pigtail or connector but make sure the heater and fan motor and the ignition switch are turn on so you can here if the motor comes on. A lot of times these blower motor resistors get hot enough to melt the connector causing it to loose its connection.
Oct 26, 2012 | 2001 Chevrolet Silverado 2500HD
1998 Dodge Ram heater air flow not working
check and test blower --possible motor failure
Aug 29, 2017 | 1998 Dodge Ram 1500 4WD
Ac and heater blower wont come on
Blower moters are usually good for about ten years. If you can run 12 volts directly to the blower moter and it wont run. It will need to be replaced
Nov 16, 2011 | 1994 Pontiac Bonneville
Blower motor not coming on for electric heater
Talk about a misnomer? Electric heat works way diff than gas heating. On electric heat multiple strips and a fan of course. But if they all come on at the same time then the breaker would trip so they use a sequencer for that job. Gas heat uses a bi-metal probe which twists around and turns the fan on when the temp reaches 110 in the plenum. Yall either have a bad fan or capacitor OR the thang that turns the fan on ain't doin it.
Nov 04, 2011 | Coleman Propane Forced Air Heater...
The furnace goes on but turns off.Its not even 2 yrs since its been put it.I changed the batteries in the thermostat.what should i do??
This sounds to me like your hot surface igniter has burned out. shortly after the induction moter starts you should see a bright glow in the heat exchanger; if you dont you need to change the igniter. In most cases the blower moter will come on and blow cold air, this is a default setting.
Apr 19, 2011 | Goodman GMS90703BXA Heater
When main switch to heater is turned on, only the flame comes on - no heat or blower. Have tried numerous times to reset by turning main switch off for five minutes, but still does not work. Any...
Does the fan come on when you turn the Fan to ON at the thermostate? If it does then it could be the blower board not turning the low speed blower tap on. Or the Fan & Limit switch not working. If the fan doesn't come on in the on position then the blower motor could be out or the run capacitor.
If the blower comes on it the ON position then you can run the heat with the fan in the ON position till you can get the heat relay looked at.
Dec 21, 2010 | Heating & Cooling
The climet control heating systom moter in my 04/Crown Vic runs at full spead at all times all I can do is turn it off or on can you help "Thanks HARDLUCK"
If you have eatc and the blower stays on with the system off. It is your blower speed controller.It's located under the hood in the evap. case under the heater hoses. Follow the wiring from over the hoses.
Mar 10, 2010 | 2004 Ford Crown Victoria
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
128 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
