It's a little tricky but here's how you get to the belt:
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
SOURCE: How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
SOURCE: belt location
Get the documentation (Owner's Manual) off this website.
Read the section on replacing the Belt. If you still have
questions then ask here.
