Question about Kitchen Ranges
Frigidaire Gallery Series gas range oven quit working.
I used open oven to help heat house and it quit working.
  • waco77000 Nov 21, 2008
    Joe (rbnsn6)
    The ignitor glows brightly (the same as the broiler ignitor, which works) but the gas valve does not turn on. Is there a way to test the valve? Is this a dual valve (w/broiler)?
    Thanks, Joe L
  • 41 Answers
Most likely, your ignitor went out. when you turn your oven on, is there an orange glow? if not, or if it is not very bright, then your ignitor is bad or going out to the point it is not getting hot enough to turn the gas on. Joe
Posted on Nov 18, 2008
Frigidaire gallery professional series oven I have
Good Afternoon John, I am happy to assist you!
I understand you are seeking a manual and I'm assuming your model number is GLEFM397DS, posted above. If so, I have located the Owner's Guide on the manufacturer website. Here you will be able to access step by step instructions on how to operate the oven. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 16, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Gallery series Frigidaire gas oven not heating up correctly
Hello Hilda, thank you for your post!
There could be a number of
any one of several underlying causes in why the oven is experiencing this
particular issue:
·Convection
heating element
·Thermal cutout
·Thermal oven
sensor
·EOC
(electronic oven control)
·Ignitor,
·Bake or broil
element
·All wired
connections
·Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat.
The parts above will need to be assessed for further evaluation by a technician since it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Aug 29, 2013 | Frigidaire Gallery 30" Self-Cleaning...
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Oven light is not working
It is most likely to be the bulb which is faulty.
You should be able to replace it quite easily, nornally the bulb cover will turn anticlockwise and reveal the bulb which you then replace , remember to use a high temperature replacement.
Jan 04, 2010 | Frigidaire FGB24S5A Gas Single Oven
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Kitchen Ranges Logo
219 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
