Where can i get a replacement ignitor. my filament is broken KW24G
  • 232 Answers
What brand? What model?
Posted on Nov 19, 2008
Low beam on driver side nit working 2010 kia soul
You need to replace the lamp as the low beam filament has broken. The lamp could be a double filament lamp, high & low. Or your car has separate lamps for each beam. Either way replace lamp.
Jul 08, 2017 | 2010 Kia Soul
I have followed instrucions to the letter but my breadmaker is still not baking bread
If your breadmake is not working at all, try a different outlet. If that does not work, replace the unit. If the breadmake is mixing but not baking, you most likely need to replace the filament.
Jul 30, 2008 | Microwave Ovens
1997neon shifter won'T LIGHTUP
see this step and fix it. God bless you
Diagnosis: The problem could be a bad headlight bulb, a loose bulb or corroded bulb socket, a bad ignitor, or a bad ground connection or wiring harness fault at the ignitor. High Intensity Discharge Xenon headlight bulbs do not have a filament, so if the bulb has failed it may be cracked or leaking. The bulb also requires a high voltage ignitor to turn it on and keep it glowing. On some applications, the bulb and ignitor are one unit and can only be replaced as an assembly. On others, the bulb and ignitor are separate components, and can be replaced separately. The bulbs are expensive to replace ($50 to $100), and the ignitors are even more expensive to replace (up to $200!), so you want to make sure you have correctly diagnosed the faulty part BEFORE you replace anything.
TIP: Swap the "good" bulb that is working on the other side to the headlamp that is not working. If the headlight now works, you know the bulb you removed was bad and needs to be replaced. If the headlight still does not work, try swapping the "good" ignitor module on the other side to the side that is not working. If the headlight now works, the problem was a bad ignitor, not the bulb. You need to replace only the ignitor and not the bulb. If the headlight still does not work, you have a wiring fault such as a loose ground connection, a bad wiring harness at the headlamp housing, or a corroded bulb socket.
Oct 16, 2012 | 1997 Dodge Neon
My headlights don't work, but the brights do. What caused this and how can I fix it?
Every headlamp has a bulb inside that has two filaments one for high beam and the other one for low beam, if any of those filament is cut then that beam (High or low) won't work. If your high beam work then your fuse it's ok, so you can visually inspect your headlights bulbs for broken filaments. remove bulb socket and remove the bulb carefully to inspect the filaments. if the filaments are atacched from one terminal to the other then the bulb it's ok, if not replace the bulb.
Jun 28, 2011 | 2002 Chevrolet Suburban
Our gas range stove stop works, but the oven does not. The filament heats up by the broiler, but the oven will not fire up.
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | Whirlpool SF3020EK Gas Kitchen Range
Running lights in rear dont work but brake and signal lights work
Possibly, the bulb type that controls your rear lights has 2 filaments/elements in it. And the filament that does the running lights is fine, but the filament that does the brakes and signals is broken. Visually check the bulbs for broken filament.
Apr 10, 2010 | 1998 Chevrolet Malibu
Left signal blinking, left brake light not workking
It seems the bulb for your car has 2 elements/filaments, meaning the bulb does the duty of turn signal and brake signal. The brake element/filament is probably broken, and not the turn signal element/filament. Replace the bulb with same model as broken one. Hope this helps.
Apr 02, 2010 | 2006 Chevrolet HHR
BOTTOM IGNITOR BROKEN,REPLACED STILL WONT FIRE
you need a volt meter to check this but if you can find you safty valve you can see if power is flowing through it by disconecting the ignitor and measuring the wire that comes to the ignitor and the other one that goes to the valve. if you have power you need to replace your saftey valve.you may allso ohm check the valve.if its open its bad
Mar 06, 2010 | Kenmore Ovens
The toaster no longer toasts..the filament is broken.
If the filament is broken there is very little you can do other than fit a new filament.
By the time you have bought and paid for a new filament and fitted it, it would probably be cheaper to buy a new toaster.
Jan 20, 2010 | Avanti Toaster Ovens
Gas Dryer Model # WGD5821SW0 The dryer does not get hot. We have shut of the breaker and turned it back on after 3 minutes as suggested. Help I have 6 loads of laundry waiting for my attention.
The heat is supplied from the gas burner. 1- If the ignitor is not on because the filament is broken then the burner is not working. 2- If the ignitor is working but the thermal sensor is broken then the gas valve is not open to sustain the flame in the burner so there will be no heat. Need to check these by accessing the back panel. Good luck
Jan 10, 2010 | Washing Machines
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
