SOURCE: 2004 Mitsumishi Endeavor
The front three should be easy enough. They are right in front of the intake plenum. (big black plastic looking thing on top of the engine. The back three are underneath the intake plenum. It seems like a lot to tackle but it is really not that bad.
As always, if you are not sure you have the skills to attempt this go to a qualified mechanic. I did mine in an afternoon.
SOURCE: CHANGE HEAD LIGHT
you change the bulb from inside the engine compartment . raise the hood and feel for a plastic retaining ring in the back of the headlite. Loosen 1/4 turn and bulb socket and old bulb will pull out from the headlite assembly Unplug the old bulb and replace with new one . assemble in reverse order.
SOURCE: Timing Belt for 2004 Mitsubishi Endeavor
Yes, I would replace it according to the owner's manual. Could be very expensive if it breaks.
Charlie
SOURCE: Cabin Air Filter - 2004 Mitsubishi Endeavor (Where?)
IT IS IN BEHIND THE GLOVE COMPARTMENT YOU HAVE TO TAKE IT OUT BY UNSREWING AND START FROM YOUR RIGHT SIDE
SOURCE: wer is bank 1 sensor 2 in a mitsubishi endeavor
Bank 1 sensor 2 is on the firewall side of the engine, and is the bottom O2 sensor (the one furthest from the engine). It is accessed from below the vehicle.
