Question about Ovens
Oven turns on by itself without being preset to do so
I have only had this oven for 2 months and on 4 different occasions it suddenly starts to beep and the oven turns itself to 350 degrees and Convect Roast or Convect Bake displays. No one has touched it and no one has preset it to turn on by itself!! I checked inside and do not see a ghost in it either, so would could be the problem? I have not called Sears yet, but it worries me to think that it might turn on while no one is at home. Any ideas? It's a Kenmore Elite 790.4670 Thank you
  • 1 more comment
  • Anonymous Dec 14, 2008
  • Anonymous Jan 11, 2009
    My oven now turns on by itself. The display does not say it is on, but the oven is hot and the fan starts blowing. We now have to turn it off at the breaker so it won't do this anymore. Any ideas of what this could be?
  • jtben Mar 03, 2009
    The oven will turn on by itself. While I thought this was just a rare experence. It happening more and more.
    What do I do?
You may have already called service and that is a good Idea since this could be a fire hazard if something was left in the oven when it comes on.
First I would check all the key lights on the oven controls to ensure that they do light. We have the same stove and several times we have brushed the top panel and turned things on accidentally. Ensure that the audible alarm is on/working - it helps.
The next strategy has to do with all the myraid of oven control modes if there is a defalult - reset to it . Otherwise cancel all timing or alternative mode methods for controlling the oven.
Has there been power outages or power surges correlating to these turn on phenomena? A surge protector if such a thing exists may be needed and static electricity may play in this as well - good luck.
Posted on Feb 28, 2009
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Ihave a minder shed alarm (4 button model) the batteries ran out and i dont know how to reset it any1 help!
Factory Code settings 1234, To change the factory code press button 1 for 2 seconds, wait for 2 beeps, now enter your new 4 digit code, you will hear a further 2 beeps to confirm the new code. If the battery is removed the code will revert to the preset code(1234)
Nov 05, 2011 | Stoves 720EF Electric Double Oven
I have a GE JTP27 double oven, now 12+ years old. For last 2-3years, having consistent problem with upper oven where, after oven heats up and/or starts baking, we suddenly get a beeping sound and an error...
its possible to be the oven sensor or something in the lock circuit...if all else fails then in the electronic oven control which costs 125.00 or there about...might find cheaper price on ebay or internet search The sensor about 40-60 dollars, but without a complete number its hard to be exact with a price or part list...if this is helpful ..please let us know or if I can be of more assistence. let me know...Bruce Denton
Dec 28, 2010 | GE JTP27 Electric Double Oven
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Amana Convection Oven - Beeping Continuously
F1 code and continuous beeping. This is a common problem with that type of Amana control. The control panel has a design problem I think, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the control panel out, and inspected it. I found a web solution, that said to shim the control panel out away from the housing slightly because it rubs on the metal around the opening and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried that, and it still did not work.....panel was still beeping. Mine seemed to be the timer control that was going on and off, and then eventually an F1 error. So, I took the panel out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it is really sticky.......and looked at the control panel itself . It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and checked to make sure none of the printed circuit paths had any wear or damage, and then put the cover back on the board. It was still sticky enough to go back on, and stay in place. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo! The pic below is just an example pic from the internet. My model is slighty different, but the panel looks basically the same. 1_23_2012_2_51_28_pm.jpg
Aug 22, 2006 | Amana AEW3530DD Electric Single Oven
F7 message with beeping
The F7 represents a shorted matrix or start key. To determine whether it's the key panel or control itself, disconnect the ribbon cable of the key panel that goes to the control and power the oven up. If the F7 does not come back, it's the key panel, if it comes back, it's the control..
Jun 09, 2006 | GE JKP15 Electric Single Oven
Ovens Logo
1,175 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
