Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Canon550 flash problem
I've had my Cannon 550 for about 6 months now and its been working very well... But the flash stopped functioning about a month ago. I can still take pictures in all the modes without flash.. but when I turn the flash on, the ready light goes on, but the picture isn't taken. Is this a problem I can fix? or should I take it to the shop?
Hi I got resolved the same problem recently with the help of Canon Local Service Center, basically its the problem with flash..
Posted on Jan 04, 2008
Having the same problem, although after about a year of having it. i've come to the conclusion that the flash itself is broken, if you shake the camera you'll hear something moving around (at least that's my case) and i'm supposing it's similar to a burnt light bulb kinda thing. so the solution would probably be to send the camera to canon itself or find someone who can replace the flash (and buy one as well). I can't do either because I live out of the US =(
Posted on Jul 05, 2007
I have a Canterbury cannon gas log fire, it worked great last winter, just tried to start it after 6 months and while I can see a spark it won't light! I have other gas appliances that work fine
Sometimes the gas in the supply line to the fire can disperse over a few months. It is worth holding on to the ignition for a couple of minutes (giving it a spark every 30 sec or so) to make sure it is flushed. If you smell gas then stop!
Apr 07, 2016 | Miscellaneous
Set time on MSP74810W
Instructions for setting an MSP74810W watch.
Press the "Mode." button three times (the "Mode" button is the one next to the lower left of the dial when facing it).The first time you press you'll see the ST, or stop watch function, the second time you'll see the AL, or alarm function, the third time you'll be back to the time of day function but the seconds will be flashing.
Change the flashing seconds digits to read 00 by pressing the "Start" button (the "Start" is the button next to the upper right of the dial when facing it).
-To advance from the flashing seconds' reading to the hour of the day's digit/digits you press the "Reset" button at the lower right of the dial,
-To advance from the flashing hour digit/digits to the minutes digit/digits you again press the "Reset" button,
-To advance from the flashing minutes digit/digits to the month's digit/digits you again press the "Reset" button,
-To advance from the flashing month's digit/digits
to the day of the month's digit/digits you press "Reset,"
To advance from the flashing day of the month's digit/digits to the day of the week's abbreviation you again press "Reset,"
-To advance from the flashing name of the week's abbreviation back to the seconds' of the minute you again press "Reset," and from there you can go through the cycle again.
While the hour of the day with its A[M] or P[M] designation, the minutes of the hour, the month of the year's number, the day of the month's number, or the abbreviation of the day of the week's name is flashing press the "Start" button once, repeatedly, or hold it down to advance the number or letters to their correct designations.
Once all designations are correct push "Mode" so that none of the numbers or letters are flashing. Your watch is now set.
Apr 01, 2014 | Watches
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Touchscreen stopped working
Get it back for warranty since it's only couple months old. They might replace it with a new one. Suspected faulty digitizer.
Sep 28, 2012 | Canon Powershot Elph 320 Hs Digital Camera...
I've got a 2002 Montana in the shop and the A/C has got a leak. The condensor was replaced 2 months ago and system pressure tested ok. Has dye in it and there is absolutely no trace anywhere. The...
The AC may stop working due to a refrigerant leak from the condenser - this is not uncommon in Montanas built between 2001 and 2003. GM has developed and updated condenser and mounting bracket to help prevent the replacement condenser from failing in the same manner.
I'm not sure why the dye isn't showing.
Usual cost of the fix is around $550.
Nov 16, 2017 | 2002 Pontiac Montana
Samsung ST550 Camera Touch Screen Unresponsive Had the camera for 18 months and over the last 3 months the left hand side of the touch screen has stopped working. The camera's lived in a protective...
I had this problem about my touch screen same with you. The touch screen on left hand has stopped working. I had it for 20 months. I live in Thailand. I think that it is the big problem for ST550. I've brought it to Samsung Customer Center. and they've introduced me to change the new touch screen. It is about USD50.00. I am bored. I used it a little bit.
Jul 16, 2011 | Samsung DualView TL225 / ST550 Digital...
How do you take a night shot? and also, how do you turn off the flash? I have a Cannon Powershot SD 550 Digital Elph I have lost my manual.
If you push the button with the flash icon and watch the screen, stop when you see the flash in a circle with a diagonal line through it. You can download a copy of the manual from the support section of the Canon website.
Dec 23, 2010 | Canon Cameras
Our Panafax UF-550 will not give us confirmations that our faxes were sent. Also, the Date, Time, and percentage is flashing and it never did that before. Can you Please help me?
Confirmations:
Press
function 74
set
12
set
set
stop
Date & Time:
Fuction 71
set
key in date and military time
set
stop
The flashing date and time is because you a dead non-replaceable back-up battery
Jul 08, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
129 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
