Question about Olevia LT32HVE 32 in. LCD Television
Having problem turning on
I have a 27" olevia flat sceen tv, I'am having trouble turning it on my tv model # lt23hvx ,my tv is only 1year old, I put in shop,they don't know what is wrong. Please Help!
Thanks! Sheila
  • smlcthompson Dec 16, 2008
    Same problem. Will not turn on with button on TV or with remote - any solution yet?
  • obstinate Jan 07, 2009
    I have an Olevia 37 inch LCD TV. After a short time the screen will just go black (or dark gray). Sound stays on. I heard that there is a "bulb" for these that may go out and cause this. Any ideas?
    Dan
  • Olevia Master
  • 5,568 Answers
Your shop has probably checked the remote and the mating receiver in the set so I would bet on (or against) the power supply. They need to check all electrolytic caps ranging from about 1uF to 100uF in the main power supply circuit with a meter that can measure both value and DF (losses) and preferably at 1kHz minimum. Those that are found failed (shrunken value & high losses) they should be replaced with low ESR types rated for higher frequencies. Additionally, they should bypass any caps so found with ceramic capacitors of no less than 0.5 uF. These caps will prevent the destruction of the replaced electrolytic caps again.
If the shop does not own such an instrument, find another shop.
Posted on Nov 18, 2008
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia LT23HVX screen resolution
what kind of cable are you connecting with? If you are using a Composite or S-Video cable perhaps you may want to use the VGA cable instead and see if that corrects the issue.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Tv won't turn on no blue light either
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Olevia LT23HVX 23 in. LCD Television
I have Olevia LT23HVX tv/pc monitor. Im trying to hook it up to my home pc but it keeps on saying OUT OF RANGE under pc. But for the tv is fine can youo help please.
"Out of range" meand the screen resolution of your PC doesn't equal the input possibilities of your screen
Check the resolution is compatible.
Feb 07, 2011 | Olevia LT23HVX 23 in. LCD Television
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Red lite comes on but tv will not power up.
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching, as my husband couldn't get it to work, but I could.
Apr 20, 2009 | Olevia LT23HVX 23 in. LCD Television
I need a driver for my LT23HVX Olevia Display
Since this is a TV, you do not require a driver for it or any display device attached to a PC. The driver you need to update is the video card driver of your PC.  Once it is installed, it will be able to communicate with your TV or monitor's EDID (Extended Display Information Data) and be able to send an image to it properly.  The internal EDID will tell the video card what resolutions it can accept.
Mar 24, 2009 | Olevia LT23HVX 23 in. LCD Television
power supply board is the board where the ac cord plugs in .the . capacitors have numbers printed on board right beside them. there are three to change also check fuse on the board to.
Mar 12, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia LT32HVE 32 in. LCD Television Logo
69 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
