Sky router not connecting to wireless - Computers & Internet
  • Anonymous Apr 06, 2009
    same again ring them
  • 4,806 Answers
Typical problem with sky, get in touch with them and tell them your problem, they will send an update to the router which should allow you wireless access
hope this helps
best regards
Posted on Nov 19, 2008
How can i connect sky through my lg dongle. what passwords do i need to enter. thanks
The password for your sky wireless will be written on a label on the sky router itself - use that
Jul 13, 2014 | LG ANWF100 Wireless dongle
I am trying to conect my laptop to the sky wireless in my house. the connection was successful but I cannot access the internet. Please help.
Do power cycle with you router
Connect to router by wire and see if it is working, in case no, Call sky, some issue from their end
In case working, issue is with wireless..
Connect to internet by wire
Open the router ip on web
Change the frequency to 6 (it worked for virgin)
Mar 04, 2011 | Computers & Internet
Netgear Wireless - G USB 2.0 Adapter
Hello, Joe.
Assuming Sky doesn't prevent access to non-sky internet services (if they did something crazy like that, it is most likely a Sky specific firmware that was put on the router, which would mean you need to put the Netgear firmware back on), I would say you have something set up wrong.
Can you get to the internet through a wired connection? If so, wireless is probably configured wrong. If you can log into the router, that would give you an easy way to find out how thw wireless is set up. goto your web browser (on a wired connection to the router) and type "192.168.1.1" or "192.168.0.1" When prompted, type in your username and password (probably, "admin" and "sky" or "admin" and "admin").
If you can't log into the router then you'll have to try and figure out the connection through trial and error. When you were with Sky and the tech installed your router, did he/she give you an encryption key to use when you connected? If so, I would try "shared WEP" first (providing the WEP key given to you). If that doesn't work, try WPA-PSK.
Hope this helps,
Bill
Sep 03, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Sky netgear router
add your previus setting in your netgear router
fist you have contect with your pc and config and fist resert the all current seting
Mar 31, 2009 | NetGear RangeMax Dual-Band Wireless-N...
I have bought a laptop from someone and it has a edimax EW-7305Pg wireless LAN Cardbus. I am having problems connecting it to a netgear wireless router supplied by sky. I have sky broadband. I uninstalled...
is the mac address registered through your wireless router, your router maybe running wireless mac filter, if not try registering your wireless mac address on your router then try reconnecting your computer to your router.
Feb 01, 2009 | Computers & Internet
I have recently aquired a router and a Wireless PCI Card. Although I am automatically on the internet when I boot up my Computer,I keep getting a message on screen that I have limited or no conectivity....
the limited connectivity means that your router is not connected wirelessly probably because you have not entered the correct passkey, or it's still giving your lan RJ45 network cable the ip address and this is why you are still connected to the net.
If you are on a Netgear modem/router as i suppose you are if it's from sky, you should connect the RJ11 phone line cable into the router leading to a broadband filter, then connect the filter to your phone socket.
There should be no wires between your pc and the router, so take out the wire that is connected to the router (RJ45), which you should have used to set the router up coming from your onboard wired network card.
You will now be connected only via wireless connection, right click on the wireless network icon in your taskbar, click show all connections and then click on your SKY****, whatever it is and then you will need to enter the WPA-PSK security passkey which is with your Sky paperwork or on the router itself.
Sep 10, 2008 | Computers & Internet
Sky Broadband problems
what wireless channel is the router set to? What channel is the 3com set to?
Jul 07, 2008 | Computers & Internet
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
