My laptop monitor does not work
White screen only / i use a desktop monitor
  • 90014 Mar 24, 2009
    This is a common prolem. Heres a link to a parts store. But, I do NOT know wich part.
    Part Number Variations
    35-d010976
    Description
    MAIN BOARD,PCBA FOR ,A220
    Your Price
    $77.39
    Detailed Description
    http://www.encompassparts.com/products/?...
    n/a
    Genius:
  • 1,913 Answers
When u power up the system press F8 key then enter in enable vga mode.or safe mode.check your dispaly resolution in control panle.
if it is 800*600 or 1024 *768 tehn its ok.thene go to my computer and right clik it properties.then advanced.then chooose best performance.
Posted on Nov 18, 2008
How would the pattern on the screen change if a pure blue screen were substituted for the white screen?
What can you do if the laptop LCD screen turned completely white? 1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard). Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop. In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful. Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 31, 2013 | Computers & Internet
White screen
Jan 31, 2013 | ASUS Computers & Internet
When start up the secreen becomes wight
Jan 28, 2013 | Computers & Internet
My acer laptop show white sceern only?
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope it helps
Jan 23, 2013 | Computers & Internet
White screen appears on computer at startup
Jan 15, 2013 | Microsoft Windows XP Home Edition
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
MSI Laptop have no disply only white screen
hope it helps
Oct 14, 2012 | MSI WIND10 N450 1.66G 1GB 250GB SYSTWIFI...
Whited out computer screen
hope it helps
Oct 06, 2012 | Acer Aspire 5732z 15.6" Laptop Genuine Hdd...
No display,only bright wihite colour screen
which brand of laptop ?
hope it helps
Sep 23, 2012 | Computers & Internet
Black screen, White blinking line on bottom of Monitor
During the move was your laptop dropped or bumped ? If so you might of unseated the video adapter from your laptop. Have you tried another monitor? I wouldnt rule the monitor as the problem. Try another monitor. If you have more questions or problems feel free to get back to me and I will do my best to talk you through a solution.
Sep 19, 2007 | Dell E196FP 19" LCD Monitor
Computers & Internet Logo
1,402 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
