Hi Guys I own a Pocket pc DELL Axim x51v Loaded with Tom Tom navigator app version 7.450 (9028) v720.1802 ab4s8bshun Connected to a wired Tom Tom GPS, in the correct cradle All of the above is correctly connected and the GPS lights up I require to know please three GPS settings for the Axim GPS programme port GPS hardware port GPS baud rate Many thanks indeed Alan O' Duffy alan@oduffy.com 07973 728 733
  • alanod Nov 19, 2008
    hi Guys many thanks for your sugggestions and congratulations on your new President elect!
    just yo be clear the GPS is hard wired to the cradle within sits the Axim X51v, and the Tom Tom GPS lights up to confirm that it is in communication with the cradle and Axim
    Also the GPS programme port number cannot be the same as the GPS hardware port, so the Axim tells me; i have tried COM 7& 8 both ways around; Baud rate as per your instructions.
    So there is not a notification icon that i can find >>> and i tried your suggestions and still not getting me home! So all help appreciated or do i give in and buy a stand alone GPS box ???
    best regards and thank u in advance! Alan O'Duffy alan@oduffy.com
    Scholar:
  • 181 Answers
Under Settings/systtem tab, you have to select the GPS icon and set the program port to "Com 7",also set  GPS Hardware port to "Com 7", and  baud rate to 57600, and then  "Manage GPS Automatically"
After u set up the pairing, and if  it doesn't give u the option to create a New Outgoing Port, just a New Incoming Port.
Then After you pair using the passkey "2003" there should a list of available services. Make sure you check the "use serial port" service.
And if still get any error just follow this steps
1. Delete the pairing in BT manager, if it exists.
2. turn on the gps receiver, then start the nav. software.
3. Let the program auto-detect. When the notification message appears, DO NOT select "yes" or "no"
4, Exit the nav. software. It will take about 20-30 secs. to exit.
5 Click the notification icon, then select "yes" to the pairing. When this is done, you can check the BT manager, and see that there is no partnership.
This seems to be the key.
6. Start up the nav. software, and it will connect automatically. Exit and start the nav. software, and it will always work.
The only problem, which I feel is minor, is when the BT communication is lost, cause then you need to start from step 2 again. Just remember to exit the software first, before turning off the gps receiver.
With this setup, you must ALWAYS turn on the gps first, then start the software. If you don't, then you  start from step 2 again.
Posted on Nov 18, 2008
  • 19,396 Answers
  • Ginko
    Ginko Nov 18, 2008
    program port to Com 7,
    GPS Hardware port to Com 7,
    baud rate to 57600,
  • Ginko
    Ginko Nov 19, 2008
    Hi I got the right settings here : http://www.aximsite.com/boards/showt...a... com1
    In your case use COM1.
    And use 4800 as baud rate
    I quote:
    "The problem is due to the corrupted serial driver name in the registry, that is why you see "Se???a?? ?a??d?? st?? COM1: " in Tom Tom GPS menu.
    1. Use a registry editor, e.g. PHM Registry Editor v0.70
    http://www.freewareppc.com/utilities...r...
    2. Locate HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial
    3. You will see the value name "FriendlyName" has some Russian characters for the value data
    4. Change that to Serial Cable on COM1:
    5. Make sure you exit registry editor from Tools -> Exit, that will save the changes properly.
    6. Now go to Tom Tom and your wired GPS should be working. You may need
    to do a soft reset if Tom Tom is still not picking up your wired GPS.
    Heres what I set my settings to in TT5(should be the same for all us
    dell wired gps + tt5 users): In TomTom 5 go to Show GPS Status: Select
    Other NMEA GPS, GPS baud rate:4800, choose Serial Cable on COM1. That should do it. give it a few seconds and it should see the satellites."
    PS we don't have president here, we have the Queen and she is not elected, thanks the same btw.
Axim x51v won't sync
Guys it's probably down other sync software on your system like phone sync, I had the same problem yesterday, sometime ago I had installed software for my HTC phone, check in add/remove programs & uninstall anything that sync with your computer, then reinstall activesync.
welshcob
Jan 03, 2013 | Dell Axim X51 Pocket PC
Is there anything i can do to update my dell axim x51v
In the settings area on the Dell, there is a link to check for updates. This is the first step to determine if your phone has an update.
The Pocket PC follow the Window CE operating system.
Go to Start/Settings/System/About: This will tell you the version of the software you are running.
The go to the Microsoft web site type in Windows CE in the search block and see if it is the latest version. If it is, no update. If it is not then you might want to try it.
good luck and don't forget to vote!!!
Sep 28, 2010 | Dell Axim X51v Pocket PC
Axim x51v operating manual
You can download the operating manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jun 28, 2010 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC, i can connect to a wireless network, but i cant open any pages, such as google?? any help would be greatly apreciated!
Go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab', and make sure that 'My network card connects to' is set to 'The Internet'.
Hope it works for you!
Just my 2 cents... Carlos
Apr 14, 2010 | Dell Axim X51v Pocket PC
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
http://www.youtube.com/watch?v=9K2P_SNTuGo
Dell Axim x50v, x51v
http://www.youtube.com/watch?v=vEDvCklrNs0&feature=fvw
Dec 15, 2009 | Dell Axim X50 Pocket PC
Forgot my password on a Dell Axim X51v Pocket PC
do a hard reset to your phone so as to work properly.here's how;http://www.hardreset.eu/dell_axim_x51v_hard_reset_soft_reset.html
Oct 06, 2009 | Dell Axim X51v Pocket PC
Dell Axim x51v
You can get a replacement rechargeable one at batterytrader, here is the link - Dell Axim X51 battery, they also do a couple of extended versions just search on the site, this also fits the dell axim x50 pda batteries
Sep 18, 2008 | Dell Axim X50 Pocket PC
Dell axim x51v and dell d810 conflict
Thats an easy one, simply uninstall your active sync reboot with axim of cradle then install newest version here : http://www.microsoft.com/windowsmobile/activesync/default.mspx
Aug 05, 2007 | Dell Axim X51v Pocket PC
Computers & Internet Logo
Alun Cox
David Payne
David Payne
