Question about GE VG4267 VHS VCR
Transport erratic - machine cuts out on PLAY/REW/REC
GE Comm Adv ('96/'97) model-
erratic since few yrs- now more consistently so. Copied over commc'l
tapes...were fine until recent probls..now snowed over & inexplicably erased.
E.g., when set to REC, at times, will attempt, but immediately SHUT DOWN. Ditto, for PLAY, REW.
Machine only used about 1/3 of its life (storage), but have PAUSED a lot & SLO-Mo'd...Never cleaned. Insides LOOK good! but can't I.D. any 'parts of causation.'
Discontinued Commc'l Adv feature, but no change in function.
s/SHUTdown in NV
A machine reset (unplugging- (x1 wk)) temporarily seemed to fix; some probls returned after 24 hrs.
Technician series text suggest probl may be Tape Load reel (gears, worn belts), tape slack sensor,
mode switch, etc. In other words, machine needs overhaul due to lack of maintenance. [ But where to get necess parts???!! ]
Audio & picture still perform well. Suspect snow dropouts due to tape age (at least late 1980s) & oxides.
/K_M
Posted on Nov 26, 2008
Tape player will not play, but FF and REW work, as well as counter. model: Onkyo Integra TA2066
This unit uses a Sankyo type transport and after all these years and functions the feedback contacts may have become tarnished or the worm gear motor may have developed a dead spot. If you take the cover off the unit the first thing is to get a burnishing tool and work on the copper leaf contacts to see if that is it. This can be done with the power off. Then test the unit to see if that worm gear cam system will rotate. If not then the next course of action is to replace the cam motor as it has a dead spot on the commutator. You can confirm this condition by taking a small ***** driver and turning the worm gear quarter turn. Then try some play functions. If it works that is the problem. You will need to get a new motor and replace this- it is very involved and not an easy part to find and so a Technical person is better off doing this. If it does not move then it could be that the drive circuit is having trouble in either the supply or the drive transistors.
You will need to measure voltage in each direction it is suppose to turn. If it does not then on to the circuit board for the drive transistors.
Mar 30, 2016 | Audio Players & Recorders
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
Tape heads are stuck will not disengage. transport will rew and fast forward but will not play or record. also could not eject tape. unit is a tascam porta one mini studio.
There is a cam system in the transport and they need to be lubricated. It might cost more than $100 to fix. Sometimes the gears have rounded off teeth that you can not get anymore.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
I push play and it stops after 2 seconds, same with rew, and fwd
Is the tape actually moving when you initiate transport commands? Most machines are smart enough to know something isn't moving when it should be. That it fails in BOTH FF and REW suggests the reels aren't moving to take up slack. Cheap machines use glorified rubber bands as drive belts for the reels. Without specifics re: make/model we can't get too precise with an answer. I'd have a pro look at it.
Feb 15, 2010 | Audio Players & Recorders
I have a problem with my Nokia E72 which shows requesting divert status message every time I restart the phone and show a blue colored phone icon just above service providers name(Vodafone in)
This icon appears due to the app adv comm manager app that came in free with the device. go to that app and ensure that you keep no filter / off as your chosen setting. The icon will disappear.
read the entire guide on how to use the adv comm manager.
Feb 13, 2010 | Nokia E72 Smartphone
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
Cassette tapes
try firmly banging the cassette onto a table top(with reels flat) a few times, then ff right through and rew a couple of times. this will layer the tape more evenly and hopefully allow the mechanism to play it. the takeup reel or autostop mechanism may be failing if the deck does not have enough torque to carry the tape and may require belts replaced or dried grease removed in the transport.
Dec 07, 2007 | Tascam 202MKII Single Dual Cassette Deck
Televison & Video Logo
67 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
