Question about Gateway FPD1775W Monitor
I keep getiing check resolution pop up. How do I do it?
The right side of monitor pops up your monitor may not be at peak performance. adjust and click auto on side of monitor. Also I cannot get monitor to power off as energy saver.
    Genius:
  • 1,913 Answers
Tpye "control:in run then go to dispaly then setings then adjust resolution to 1024*768.
for power enregy go to power option in control panel u see power shems then set minutes to shu off monitor.
Posted on Nov 18, 2008
Auto adjusting
This is normally caused when the monitor does not support the screen resolution the computer is set to. Change the screen resolution and see if that helps. Also, consider updating your graphics driver too.
Hope this helps
Steve
EmoticonIT com Computer Solutions Lincolnshire Joomla Websites IT...
Apr 30, 2014 | NEC AccuSync® LCD73V 17 inch Monitor
I have an acer AL1912 and a (auto config please wait) gray box keeps popping up,how do i stop it
If it gives you message about the resolution, set the computer to use native resolution of the monitor. You can change the resolution by right clicking on desktop and choosing "screen resolution".
Dec 27, 2013 | Acer AL1912 19" LCD Monitor
Resolution notice
Your monitor is not running in its native resolution, so there is notification to change your display resolution, then you have to check driver for your video card. Upgrade the driver fot your video card. Where will be the setting to change to 1440 x 900.
Nov 08, 2013 | Envision G19LWK Monitor
Font to big
to use another type of font look into:
start -> settings -> control panel -> Fonts
other solution is to adjust your display to use another higher resolution:
right click on empty space on the screen and select property
a window title "display property" should pop out
select the tab "setting"
on the middle of the left side there is a bar for increasing / decreasing
the resolution
hope it helps
Mar 10, 2011 | LG 22" FLATRON LCD Monitor
Dell inspiron 1100 bought used reinstalled xp and monitor had only 6 inch image adjusted resolution, it grew almost perfect one more adjustment now quickly shuts. down image Windows logo with start up...
You may have set the resolution/refresh higher than is possible for the laptop to produce, Try booting into safe mode (F8 on power up)
if you can, you can now reduce the resolution to the monitors default resolution.
If you have not already, pop over to the dell support site and download the right driver for your display
Jul 19, 2010 | Dell Computers & Internet
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Jun 09, 2009 | HP w1907 LCD Monitor
Changing font size for larger monitor.
You can adjust your settings to something more to your liking by right clicking on your desktop in an empty area - then choose "properties" from the menu that pops up.
In the new window go to the tab that says "settings" and adjust the screen resolution to something a little larger. If you change your desktop settings in this manner then a window will pop up immediately after the adjustment asking you if you want to keep the new settings or revert back to the old one. If you don't select something within like 15-30 seconds it will change back. It does that just in case you change the settings so bad you can't see anything.
Another place to adjust the size of your fonts is to go to the "appearance" tab of the same menu and look for "font size" and there you can make your fonts bigger and ridiculously big, in case you still need to after changing the resolution.
I hope you find this information helpful, have a blessed day!
Dec 12, 2008 | Dell E173FP 17" LCD Monitor
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
Gateway FPD1775W Monitor Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
