Question about Whirlpool Calypso GVW9959K Top Load Washer
Keypad Needing a little guide as how to begin to remove the keypad from the washer and install the new one. Maybe asking for help some time back I miss called this part "touchpad" which I ment is the keypad, maybe this will get me help. Thanks, Slats
  • Ralph Jones Dec 11, 2006
    Thank you very much for the advice
    Slats
    President:
  • 878 Answers
Slats, on each side of the top consol there is a clip. Slide a putty knife under each end and push on the clip. The top should pop up. From there you should be able to see how the end caps are removed so you can replace the touchpad panel. Catriver...post back.
Posted on Dec 10, 2006
GE Microwave keypad partially working
You have a failing membrane keypad.
On some models you can order just the membrane keypad. It's more work, but it's cheaper.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, you have to order the control panel frame which comes with a new keypad already on it.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Some connectors have a lock.
You can order GE parts from Sears hereimage-4235112-10659157 and the site should have helpful exploded views.
Nov 30, 2012 | Microwave Ovens
Tip
Repairing an (F2 E0 or F2 E1 error code) Failed Whirlpool Builtin Oven Keypad...
A replacement touchpad is now available from Ledgestone Technologies to replace various membrane keypad switches that are not available from the OEM.
These are in stock and can be shipped today from fixyourboard.
Find the full list of applicable models here:
Introducing the Ledgestone Technologies Touchpad
Step 1. Remove Original Plastic Bezel
BE SURE TO REMOVE POWER TO OVEN FIRST!
You are going to re-use the original plastic bezel. Remove the panel from your oven that contains the keypad and control board. Uplug the keypad from the control board. Remove the control board from the panel (4 screws).
Step 2. Remove Original Touchpad Membrane
With a heat gun, lightly heat the original keypad from the back of the panel. This will soften the adhesive. Gently but firmly push the old keypad off the bezel by pushing from the back of the panel on the keypad window. Carefully remove the original keypad membrane element. Most of the original adhesive should pull off with the keypad. Rub off any remaining adhesive.
Step 3. Install New Ledgestone Touchpad
Remove adhesive backing paper from the Ledgestone Technologies KP1308A1 Replacement Touchpad Membrane. Align and adhere new touchpad to recess in plastic bezel. Below are examples of black on black and gray on white. Gray also looks good on bisque or almond.
Step 4. Re-install Bezel on Oven
Re-attach control board to bezel, plug-in new keypad. Re-attach bezel to oven frame. Done!
Applicable Models
RBD276PDB10 RBD276PDB11 RBD276PDB12 RBD276PDB7 RBD276PDB8 RBD276PDB9 RBD276PDQ10 RBD276PDQ11 RBD276PDQ12 RBD276PDQ7 RBD276PDQ8 RBD276PDQ9 RBD306PDB10 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDB14 RBD306PDB15 RBD306PDB7 RBD306PDB8 RBD306PDB9 RBD306PDQ10 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDQ14 RBD306PDQ15 RBD306PDQ7 RBD306PDQ8 RBD306PDQ9 RBD306PDT11 RBD306PDT12 RBD306PDT13 RBD306PDT14 RBD306PDT15 RBD306PDZ10 RBD306PDZ7 RBD306PDZ8 RBD306PDZ9
Original Whirlpool Touchpad Part Numbers
4451969 4451970 4451975 4451976 4451977 8300431 8300432 8300437 8300438 8300439 8300640
on Aug 17, 2015 | Ovens
Tip
How to fix a remote
If your remote don't work out in some keypad/button only then maybe the possible problem are:
  • on the keypad/button maybe it is little bit hard or soft to press.
  • maybe the keypad/button has a short pointer inside the keypad/button so that it cannot reach the board.
  • or the keypad/button just can't reach the board because it is not in exact location.
  • the board has an ashes so it does not work.
Regarding those problem above you need to do/apply the steps below.
1. Open the remote by unscrewing the back cover of the remote.
2. Then you will see the remote control board ( the remote
control board is the one with lots of many circle,colored: black
with green) try to remove it slowly.
3. Then find any cotton thing like cotton buds and also four pieces
of small hard paper.
Clean the internal remote control board using the cotton
material/cotton buds.
4. Then try to have/put a thing like a small four pieces of hard paper
inside,underneath the board in both four sides (it should be balance
by each other side) of it then try to see if the keypad/button is
being reach by it.
5. Then if done, when assembling it make sure that the board is well
done/place in the right position and exactly in the front of its
assigned value/number.
6. Then when done assembling try to test it in actual if it works.
I hope this steps could be helpful..If not maybe the battery is old enough to use and need to replace for a new one or some connection near the battery has cut off, if it is the problem just contact me for some/other solution..If this solution helps you I would be very glad to here it!! Thank you!!
on Jun 06, 2011 | Televison & Video
Replacing the keypad
A full model number would be very helpful, but since you've not posted it, we have to just give generic advice.
You can find links to helpful exploded view diagrams and part ordering help here.
If on your model you have to order the separate membrane keypad, here is a handy guide with pictures showing you what's typically involved.
If you can order the control panel frame with a keypad already installed, it's much simpler.
In this second case, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller assembly is loose from the oven, you need to remove the keypad strip, then take your board out of the old frame and put it in the new one.
Some connectors may have a lock.
Sep 04, 2012 | Samsung Microwave Ovens
Jmc8100 built in over jmw8530cas. only button on touchpad that works is stop/clear. turn breaker off for 12 hours, can set clock, use once or twice come back in 5 minutes, and only stop/clear beeps. have...
On some models, you have to replaced the keypad separately.
On other models, you can replace the whole control panel frame, which comes with a new keypad already installed.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also get details there if you need more help with the repair.
Oct 15, 2011 | Jenn-Air JMC8100 Microwave Oven
Code f2E3
It appears that this code is a code for "keypad spill" so it somehow may have gotten liquid inside the keypad. It may be as simple as removing the face panel and wiping clean the keypad and putting it together, or you may end up needing to purchase an entire keypad and installing.
Mar 08, 2011 | KitchenAid KESC308LSS Electric Kitchen...
Garage keypad not working. Installed new battery, reset code and it worked once.
You normally would not have to reset the code after replacing the battery. It remembers the code. I think you have a bad keypad or maybe the battery or battery connection is bad. Even a new battery can be faulty at times.
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Read-out shows F3
On a GE microwave, "F3" means a bad membrane keypad.
You can order a membrane keypad here and install it yourself according to this handy illustrated guide, or we can install it for you.
If the keypad is not available separately, you can order a control panel frame assembly here, which comes with a new keypad already installed.
But since this was posted under Jenn-Air, that confuses the issue. If yours is a Jenn-Sir, please post a new help request here on FixYa and include the full model number from the tag, or contact us for a free estimate and tips.
Aug 18, 2010 | Jenn-Air Microwave Ovens
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
GE Spacemaker XL Microwave
Sounds like a failing or wet keypad or *maybe* the controller.
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
This can usually be fixed economically, but please look over this response and then I'd be happy to help further.
Please rely back to this thread if possible when leaving replies.
Dec 02, 2007 | Microwave Ovens
Whirlpool Calypso GVW9959K Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
