Question about Garden
Echo blower motor will not rev.full throttle--only about half
Have checked the muffler,cleaned the air filter
  • 1 more comment
  • hammondt15 Dec 27, 2008
    I have the same problem. I have a Echo PB-261L. Has blue spark, Gets gas, New carburator, New fuel filter and hoses in tank. When all new parts were put on, ran great at full throttle. Now will not run full throttle most of the time. Acts like it is starving for gas but has a solid primer of fuel. No leaks at carburator or hoses. Choke it to get it going. When hot, harder to start. Still has blue spark. Boggs down just like it starving for fuel. Pulled muffler and cleaner port from carbin. Blows excellant air when running.
  • josh1111 May 11, 2010
    can you adjust the carb screws, if so how many screw are on the carb?
  • John McKinney May 11, 2010
    just a suggestion to you guys. i know it's a long-shot, but have you tried checking your throttle cable? this could be broken and/or stuck. let me know if this helps at all. thanks.
    An expert whose answer gotĀ voted for 100 times.
  • 87 Answers
Check the insulator block and associated gaskets behind the carb. Sometimes the insulator block crack and reduce the amount of vacuum to the pulse diaphragm.
Posted on Apr 10, 2009
How to check exhaust on a stihl grass trimmer fs45c
if your problem is it will idle but not rev up then clean your screen in the muffler and check muffler for carbon
Oct 04, 2014 | Stihl Air Filter 4134 141 0300 for FS120 /...
Mcculloch M51 550CMD
I would check the compression may not have enough to run it or the muffler may be clogged up check both
May 12, 2014 | Garden
My stihl 021 runs for 30 seconds then stalls
remove the muffler and run it after finding that it runs fine open the muffler and clean the screen inside (it is made to open to clean it)
Jun 22, 2012 | RTO Spur Sprocket For Stihl 017, 021...
Clogged air filter
a plugged air filter you can see often over looked it a plugged screen inside the muffler remove the muffler and try running it if ok open the muffler and clean the carbon from the screen
Apr 15, 2012 | Garden
Craftsman weed wacker bogs.but idles good .rebuilt carb, new spark plug cleans filters. No luck help
hello, it may be a good ideal to check the muffler they get clogged up a lot,remove the muffler and start if runs than the muffler is clogged,i soak over night is spirits and clean with a wire brush and air pressure,useally works,hope this helps,,
Jan 05, 2012 | Craftsman Garden
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My chainsaw starts without muffler but not with it on, what's the fix
If the muffler is clogged or damaged there will be too much back pressure for the engin to run. Check for free flow. Also, check the intake air filter to make sure it is clean so there is amaple air flow. Lastly, is there a safety shutoff related to the muffler that is being activated impropperly?
Jun 17, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Runs good without air filter, but badly with air filter. New air filter no help. The engine was partially submerged in hurrican Ike and a new carburator was just installed. With air filter in it runs very...
Check the Exhaust Port and Muffler.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
If the Exhaust Port and Muffler are Clear, then
Check the Carburetors Metering Needle Valve.
If the Metering Valve Plunger (on the Carburetor Metering Jet Diaphram) is Set too Close to the Needle Valve Actuator Arm, then you will have this Problem.
I Require the OEM and Model Numbers Off the Carburetor to be of Better Assistance to you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
May 09, 2009 | Garden
Garden Logo
1,202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
