Question about Motorola Mobility A630
2, 3 and 9 phone buttons do not work
Keyboard works fine . In phone mode , 3 of my keys do not work . Further , the Sim hold-down clip does not stay put anymore . Any advice? thanks , mike
    Brigadier General:
  • 7,752 Answers
The keyboard may need to be service so take it and get a service.
Posted on Mar 25, 2008
I changed my pin code to get into my zte prelude phone. Is there a default code (s) that will let me in my phone???
well michelle, if you forgot your pin to unlock your phone you might need to factory reset it if you ever want to use it again there are a number of ways of unlocking an android phone which are included in the link to enter factory mode/recovery mode press and hole volume down and the power on key at the same time when the phone is off and hold these keys until you see the logo of your phone. Instructions are available at the site below :
www.joyofandroid.com/how-to-unlock-android-phone/#
Just copy and paste in the url bar of your browser
Jul 07, 2015 | ZTE Cell Phones
Phone says "no sim card."
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 19, 2011 | Apple iPhone 3G
My HTC Shadow goes to the white Tmobile Shadow screen and gats stuck and wont go any further. I can't turn it off using the keys I have to take out the battery to turn it off
the "soft buttons are right below the screen hold both down then turn on the phone this will make the phone ask if you want to reset to default so try removing the batt , mem card and sim card first as this it the last resort you will lose all changes made to the phone except mem card and sim card stored items worked on my shadow fine good luck peeps
Aug 21, 2009 | HTC Shadow Smartphone
My phone screen won't come on, it will ring if I call it, but the screen stays dark so I can't answer it... I have tried the small button on the top and the round button below the screen.
Try these resets:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 27, 2009 | Apple iPhone 3G
In phone mode i can hear the caller but the caller can not hear me. Works ok in bluetoother or speaker mode.
Reseat the SIM card:
To remove the SIM card, insert the end of a small paper clip into the hole on the SIM tray.
Insert the SIM card using the same method.
Note: For best results, use the SIM card included with iPhone.
Then try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Thanks, Joe
May 15, 2009 | Apple iPhone (16 GB) Smartphone
Brotherintellifax4100...will not copy, send or receive fax
This might work: Press Menu, Mode, 0 to enter the Maintenance Mode. Then touch 91 to clear most of the machine's memory. (But not your phone numbers & stuff.)
More likely, that won't work, because your keyboard is messed up. These machines won't allow you to press a key when another is still down. Is one key sitting lower than the others? Or maybe water has been spilled in the keyboard? The keyboard itself might be bad. I've had to replace one only once, but it happens.
May 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Spilled coke on the touchpad and keyboard of Acer Aspire 5920
Not so sure on the touch pad, but the keyboard is easy to remove. Make sure the laptop is switched off first.
There are a series of little clips holding the keyboard on. Look along the top above the F keys you will see 3 or 4 little clips, push each of them in and up (away from the keyboard) using something thin and blunt so as not to cause any damage.
There will also be some little clips each side of the keyboard, these do not push in, you need to manoeuvre the keyboard past these.
Lift the keyboard from the top as it slots into some grooves at the bottom. There will be a ribbon cable connecting it to your laptop, this is easily undone and the keyboard is off.
Jan 25, 2009 | Acer Aspire 5920-6727 Notebook
Wont play.. stays paused.
Turn off. Put in Hold mode. Hold down middle button. Plug in while still holding middle button. Now reformat the Clip and update the drivers.
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
OK...THAT DIDN'T HELP
Sidekick II reset:
Drain your battery until your phone refuses to turn on, then charge it, the privacy lock should be off.
Press and hold the Menu key (the one with 3 lines) + the shift key and finally the "Q" key all at once.
Okay so you're at the privacy lock screen.
Okay press the Menu key and the Phone Mode key (the one with the circles) at the same time.
This should take you to emergency phone calls
Hold down the Back key (the one with the arrow) DON'T LET IT GO.
Now press MENU and PHONE MODE at the same time, now let go the BACK KEY
but
DO NOT let go MENU or PHONE MODE
Then press BACK again and let go of MENU and PHONE.
Now press MENU and PHONE again and then let go of BACK.
It takes like 3 times to unlock it
but it always works.
Jan 21, 2008 | T-Mobile Sidekick II
Motorola Mobility A630 Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
