''place paper in drawer''
When I turned the machine on today an error came up that said '' place paper in drawer'' the drawer has a roll of paper loaded already. I have reloaded rebooted, reloaded several times but error still keeps coming up.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of the copier
    Scholar:
  • 78 Answers
Sounds like a paper sensor ; A little black arm that senses paper tray is full, when the tray lifts into position. You might pull the tray and with a flashlight look for any broken parts. I have seen these break when paper jams are removed. This is a Toshiba 2860 correct?
Posted on Nov 19, 2008
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Want to know how to load thermal paper on my sharp Fax model FO-71
1 - Grasp the finger hold and pull up to open the operation panel.
2 - Flip up the front paper guide.
3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
4 - Unwrap the roll of thermal paper and insert the paper shaft.
5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
• Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
come out blank after printing.)
6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
7 - Make sure the paper comes out straight, and then flip down the paper guide.
8 - Close the operation panel, making sure it clicks into place.
• FO-71: A short length of the paper will be cut off.
Dec 01, 2010 | Office Equipment & Supplies
The paper drawer is stuck on my new Samsung CLP 310
Turn the printer off. Unplug it completely. Very Carefully, roll the printer onto one side. Push the paper drawer in as far as possible, then, by grabbing the bottom of the paper drawer, and the front of the drawer with your opposing hand, slowing slide the drawer to release the pressure and slide it out at the same time. Pressure from the rollers pulling paper from the drawer will jam the paper between the drawer so tightly that the weight of the machine will act as a clamp. When your remove the weight of the machine by rolling it on it's side, you can slide the drawer out easier.
Nov 15, 2010 | Office Equipment & Supplies
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
We have a dell 1710 printer and it is continously jamming , it seems to be sticking when it is feeding from the bottom drawer, and when you pull out the drawer the paper is getting stuck in the drawer...
Solution migh be is to check whether there are paper pieces stuck in between rolls. Also you migh try to apply some grease in to rolling conjuction. Prior doing above just try to roll it by hand whether it rolls freely
Sep 23, 2009 | Office Equipment & Supplies
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Document jam
I had this totally annoying problem this morning. After looking for any obvious paper jams or small bits of loose paper, I tried several fixes: 1) open front cover, release levers that hold white rollbar in place, roll the bar forward to make sure nothing is stuck behind it, snap levers back in place; DID NOT fix the problem; 2) open top cover, remove print cartridge, look for jammed paper bits, close cover; DID NOT fix the problem; 3) unplug the machine, wait a few minutes, turn machine back on; DID NOT fix the problem. I even unplugged the machine, opened ALL the covers, turned the machine upside down and shake it to see if any paper clips, staples, or other objects have fallen inside the machine; DID NOT fix the problem. FINALLY, I pulled the paper feed tray forward, reached down to the feed rollers, twisted them a few turns, put paper back in the machine, and the "paper jam" message disappeared! This may not work for everyone, but it worked for me today, so I hope this helps someone out there to have a better day.
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
May 11, 2008 | Office Equipment & Supplies
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
89 people viewed this question
jasbo
jasbo
