Question about RCA R56WH76 Projection Television
My RCA tv model R52wm24yx51 not get on
When you turn on the light green get on, but right away get off
I would like get the blue prints in order to fix. thanks
rodriguezpolpo@yahoo.com
  • 1030 Answers
SOURCE: RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
Posted on May 12, 2008
yambo
  • 230 Answers
SOURCE: RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Posted on Aug 13, 2008
joboo1
  • 257 Answers
SOURCE: My RCA 50'' DLP Rear Projection TV will not turn on
Hi, This could be several things as the power goes everywhere. Long distance troubleshooting so hang in there. First try a cold reboot by unplugging and replugging after 30 minutes. If nothing check P1 on the light engine for the following voltages: pin 2 5vdc, pin 3 3.3vdc, pin 9 3.3vdc, pin 12 12vdc. If any of these are not good it is the formatter board. If all are good, does the color wheel spin at all. If this is OK then check J4 on the light engine, the ballast enable line should be 0 vdc in stby, .5 vdc at turn on, and 2.5 to 3.25 vdc in run. If good, is the light engine trying to fire the lamp? If not, inspect the J4 connector and the lamp power supply, If they look OK then the lamp ballast is probably bad. This will give you something to do for now, Good Luck!
Posted on Feb 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Posted on Mar 06, 2009
  • 6 Answers
SOURCE: TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Posted on Jun 21, 2009
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
My rca tv 52
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 21, 2010 | RCA P46924 46" Rear Projection Television
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
Tv wont turn on r52wm24yx51 cant see the next number
Replace CP150, CP120 and CP114 on the deflection board. You can get the repaor kit at the following link listed under RCA repair kits www.tvrepairworld.com
Aug 29, 2009 | RCA D52W19 52" Rear Projection Television
Picture problem on 52 inch rca rear projection tv
convergence problem. need the model number of your tv in order to assist you.
Jun 23, 2009 | Televison & Video
How do I get sounds when I use the red green blue rca hook ups?
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
Nov 28, 2008 | Initial DTV-171 17 in. TV/DVD Combo
Open Questions:
RCA R56WH76 Projection Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
