Question about GE Washing Machines
GE washer washer is overfilling and running onto floor
  • 41 Answers
Mostly likely your pressure switch has gone bad or the hose has come loose from the pressure switch. open access to the console. your pressure switch is the water level. if the hose is attached, then the switch itself is bad. Joe
Posted on Nov 18, 2008
GE Super Capacity Plus won't stop filling
Does it stop if you stop the cycle or do you need to turn the valve off?
What is the complete model number of your unit?
Feb 17, 2013 | GE 3.2 cu. ft. Washer
I have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the clothes had spun dry, water was observed on floor. Drain tube checked and okay, not plugged up. Before I open...
Normally water on the floor can be from a few places. Mostly a faulty drain pump: possibly a tear in one of the pipes: rust in the drum: possibly water in the centre which comes from the bearings.(if the machine makes a racket when spinning, then i would look at the spin bearing collum). even concider drain pipe at outlet not running out onto floor. Either tilt washer back about 45 deg. to look underneath or possibly remove panel to allow a visual of the motor and components. See if you can pick up any indecationof water having run down from a particular spot. If so rectify. Hope it helped. .Ge washers not farmiliar to me but most problems are similar.
Sep 17, 2009 | GE WJSR2070B Top Load Washer
Washer over fills and floods the floor
Morning. There is a Water fill level switch in your unit that monitors the level of the fill process. this switch is malfunctioning and, it will need to be replaced asap if possible.
Jun 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't stop filling with water.
There is a pressure switch with a tube to the water drain. The switch may be faulty or needs adjustment. The tube may be blocked or disconnected.
May 12, 2009 | Maytag LSE7806A Top Load Stacked...
Some water drains out onto the floor.
the drum seals will need to be replaced. there are seals that are used for the screws that connect the drum to the drive. they are leaking.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Will not spin and then when I try to start the cycle over all it will do is aggitate. It is also overfilling and spilling onto the floor. It is a top loading GE washer and is just over a year old.
sounds like the water level switch is not working pop the front cover off and see if the tube on the left of the tub is still hooked up. to remove front cover use a putty knife and slide between thee top and the front cover you wil feel the knife stop about two inces from each side push in on the place where it stopped and pull out on the front cover
Dec 05, 2008 | GE WBSE2090A Top Load Washer
Overfill problem
with putty knife press clips on each corner about 2-3 inches fron side front drops off ck small almost clrar hose left side that plugs onto side of tub be sure it is clean on end ..they are bad about plugging up right at end ..if still have overfill problem see if water continues to run in with power removed if so fill valve bad to late for cleaning if water shuts off with power removed suspect water fill switch..remove screws along back edge of console and roll console forward to acess
Jul 23, 2008 | GE WBSR3140DW Top Load Washer
Lg washer
make sure your machine is lavel and just a little higher in the front about 1/16 in and do not fill all the way to line just under line
Oct 22, 2007 | LG WM-2277HW Front Load Washer
Washer
There is a thin tube going from the control to the drain area near the exit of your machine... this tube is likely to be clogged. Remove the clog & to check blow into it to see that it is free, refit.
Aug 04, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
115 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
