Emerson Tv lc32oem82s
How do I get my hands on the transformers that need to be replaced on this TV?
  • valeriemertz Nov 20, 2008
    I have e-mailed you some information. Thanks for you help
  • Anonymous Dec 18, 2008
    WHERE CAN YOU GET THE TRANSFORMERS
  • 16 Answers
I would assume you could go into any tv repair shop and order them the part number is LTZ2PCOMS008. To find out which one is bad you will need to check them with a meter the reading should be beyween 300-600 ohms reading between the last two contacts,closest to the edge of the board, on each side of the transformers. Once you take the back off of the set and take the board off flip it over.As I said Ihave never had to buy them so if you can't find them write back and I will send you a couple. My email is cfharold @yahoo.com
Let me know if this helps.
Posted on Nov 19, 2008
Need a power mother board for a emerson 32 inch tv model number lc320em2
does anyone have the part # for the power inverter transformer for the LC320EM2 A the board #BA1AFGF0102 2. The transformer I am looking for is the largest yellow transformer, thnks.
Sep 03, 2012 | Emerson 32-inch 720p LED TV Refurbished
My emerson 19in wont turn on making high pitched sound
Line Output Transformer shorted. It has to be replaced.
Apr 22, 2012 | Emerson ET-20F7 19" TV
I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Mar 02, 2010 | Emerson LC320EM8 32 in. LCD TV
I have a sylvania 32In tv that uses the 3pc0xb001 transformer. When I replaced the transformer it to burnt out then I found a bad mov transistor and was wondering if this would take out the transformer.
normaly when is the compatible transformer, dont take out, but you must have changed to universal transformer, and use the wrong power settings, and burnout tv and transformer also.
Jan 16, 2010 | Emerson EWL20D6 Television
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
It being emerson 32" hdtv lcd turns on but immediately turns off
This is Emerson's #1 problem.
The Inverter Transformer on the power supply/backlight inverter board goes bad. It's what powers up the screen for your TV. When the part goes bad, it doesn't have enough juice to power the screen and the TV automatically turns off. You have 5 Inverter Transformer on your board.
You can fix the problem by replacing the whole board or replace the bad Inverter Transformer.
Here's where you can get a new board for a good price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc320em9+inverter
Or, here's where you can get replacement Inverter Transformers:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Jun 17, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Flat Panel Emerson Tv lc32oem82s
Answer your first question. yes, it is the same part.
To help you with the second question I need some info.
1. Do you have a multimeter?
2. A sodering gun with new soder and soder removal braid?
3. Sodering skills on circuit boards?
Jan 26, 2009 | Emerson EWL3706 37 in. LCD Television
Emerson lcd 20s5 TV
I work for a repair company fixing emerson and many other sets. the fix to your problem is one of the inverter transformers, there are 6 in the 32". once it has been replaced the set will work great.
Jul 01, 2008 | Emerson EWL20D6 Television
Emmerson tv
what type of help you require please write here.
Oct 17, 2007 | Emerson EWF2704 TV
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
