Question about Sony PlayStation Portable (PSP) Console
Psp won't read game disks.
The psp has power and appears to be working, but when a game in inserted, it does not appear under game on the menu and then after a few minutes, the message, "the disk could not be read" appears.
  • tessa paredes Nov 19, 2008
    my psp wont play a game but it works just fine. I try to load it but sometimes it doesnt load the main screen, until i open the place where you insert the disc. it will only load a game after a day or so but then it freezes. it also makes loud clicking and whirring noises its never made that noise before. PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!
    Scholar:
  • 62 Answers
Try taking a soft cloth and gently wiping the lense.
If that doesn't work, you may have to do a reset.
scroll all the way to the left in your menu,
scroll down to "system Settings"
click x
select, "restore default settings"
click x
If after that it still won't work and you've had it less than a year. You'll have to send it in to Sony.
Go to http://www.us.playstation.com/support/warranties/psp and click on "How to obtain Service"
toward the end of the last line in the 3rd paragraph from the bottom.
If it has been more than a year, you'll have to pay to get it fixed either through Sony or somewhere else, or just buy a new one.
Let me know if any of this helps.
Posted on Nov 18, 2008
  • Simon Downey
    Simon Downey Nov 18, 2008
    Dude, how is that not at least helpful? Thanks for Trying? If none of that fixes it, it is broken and you have to get it repaired.
    Problem Solver:
  • 7 Answers
This is, unfortunately, a pretty common problem with some PS3 models. it's almost always a hardware issue where the lazer lens inside the PSP fails or is otherwise no longer able to read game discs.
The only real fix for most people is to send it in to Sony for replacement; but that's only good if it's still under warranty (they'll want a copy of the original receipt).
Otherwise, your only choices are to get a new PSP or only play games stored on the memory card.
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/benjamin_494963e790f97efb
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
After I run ChicHENR2 and GEN C (so it will have GEN C FULL as CFW) few minutes it will start lagging. can someone help me :(
Hi, I have a psp same as yours 5.03 gen-c.It requires chickhen. If it hangs in the photo folder when you use chickhen, just try and try until it works.But if an hour it does not work.Choose settings in the home menu of the psp in the system settings then restore default settings then try again the chickhen. After that run the cfw enabler in the game menu.It usually restart your psp then try pushing the button select if a menu appears then it is on 5.03 gen-c. Then you will be able to play games.
Feb 22, 2011 | Sony PlayStation Portable (PSP) Console
When I insert a new UMD i get the game could not be started. 80020148. The UMD is recognised and the thumbnail appears on the menu, but the game will not start. Please help.
Solution: 1) You must first backup ur data on your memory stick to your PC. Mainly the saved games data. ( directory is PSP\SAVEDATA) 2) Format the memory stick using the PSP format tool in system settings...not your PC. 3) In System Setting UNCHECK or UNSELECT "UMD Cache" this must be off!!!! 4) Connect your psp via USB cable 5) Copy your game saves / data back to your psp remember >> PSP\SAVEDATA . 6) Do a hard reboot of your psp ie hold the power switch for 3 seconds and it will reboot. 7) Your UMD games should now work with no probs.
Nov 25, 2010 | Video Game Consoles & Games
WHen I turn on my PSP I get a yellow screen/Menu. It has Settings, Camera, Music, Video etc. How do I exit this to play a game?
This is the XMB its the main menu of the system. Games will be located under the Controller Icon. To play games insert a UMD, or if a game is downloaded and saved on the memory card, go through the icons under Controller icon. A disk icon will appear and show a preview screen to the game, press X to start the game.
Jul 24, 2010 | Sony PlayStation Portable (PSP) Console
PSP Game error - the game could not be started - 80020148. PSP firmware is 4.01 M33-2
  1. go to ur M33 Recovery Menu.(it can be access by totally turning of your psp-holding the power button up...and then turn it on again but hold the R button.. It should appear as it turns on..)
  2. go to the configuration and press Xbutton..
  3. browse and go to UMD Mode and
  4. check if it set to <currently: M33 Driver -NO UMD>if not, just press x until it appears...
after that exit in that menu...games should play after that setting..i have encountered 8 psp's with that kind of problem...
trust me you dont want to go to a service center unless you can have a solutions on the internet...coz it will cost you 500-700php
Apr 29, 2010 | Sony PlayStation Portable (PSP) Slim...
Sony psp version update
Try updating it manully by going under settings then software update. you need WI-FI though but it is worth it
Nov 25, 2009 | Sony PlayStation Portable (PSP) Console
I know there are games in my psp but the psp is not showing them
you have to save the games in your PSP/GAME Folder. The PBP Files should have its own folder under the GAME Folder and the games should appear when you click on it in the XMB Game Menu.
Jun 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Everytime i turn on my psp only the baacklight appears what can i
You propably have a faulty or dirty game, try cleaning the disk with a soft cloth, also try other game on your psp to make sure or try the game on other psp.
Hope it helps
Jun 20, 2009 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
