Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi Projection TV WD-62525
Return from 30 day vacation, tv picture&sound did not come on. Lamp statu was red; Replaced lamp with new one provided by Mitsubishi - no change i.e., no picture no sound. Disconncedted, reset no help...What else beside a bad lamp would cause a red lamp status? Haven't been able to find a qualified technican in the San Antonio, Tx area.... Tony
  • 7 more comments
  • Anonymous Dec 10, 2007
    JUST REPLACED DLP LAMP ON MY WD-62525.TV WORKS FINE TILL YOU TURN IT OFF.WHEN YOU TURN IT BACK ON THERE IS SOUND BUT NO PICTURE.WE RESET IT BUT IT DOES NOT HELP.IF WE TAKE THE LAMP OUT AND PUT IT RIGHT BACK IN THE TV WORKS GREAT TILL YOU TURN IT OFF THEN WE HAVE THE SAME PROBLEM SOUND BUT NO PICTURE TILL YOU PULL THE LAMP OUT AND PUT IT BACK IN.THE LAMP IS A MITSUBISHI LAMP.CANT IMAGINE WHAT THE PROBLEM IS BUT I HOPE IT IS A SIMPLE FIX.CAN ANYONE HELP?
  • Anonymous Jan 25, 2008
    i have the same problem,change lamp,but tv will come on but no sound or picture
  • Anonymous May 10, 2008
    I'm having the same problem! How did you fix your TV? What was the problem?
  • Anonymous Jun 08, 2008
    Our TV does the same thing. No picture but sound is working ok. The XBox works just fine when we use it on the TV. What is wrong with mine and why won't cable show?
  • nunus11 Dec 22, 2008
    I replaced the lamp on my TV and it worked fine for a few days and not the TV is not working again. I get sound for a few seconds but no picture and then the tv shuts off.
  • smanoguetra Jan 31, 2009
    I just replaced the lamp on my Mits wd 52525 tv, however, the tv will turn on with no sound and just blackness, the green light will come on and blink for about 5 min then the red lamp light will turn on and the tv will shut down. Please help me!
  • eddygee357 May 01, 2009
    Does anyone know the error codes, mine is a 44 and I don't know what that means.
  • mtmeiser Nov 22, 2009
    We own a 32 inch Protron TV and when we turn it on it won't power up
  • Dickiedo May 11, 2010
    I found the error code on my tv - now how do I enter the error code on the front panel?
I RECENTLY HAD A LAMP ISSUE THAT MAY ASSIST. I HAVE A MITSUBISHI WD-52525 52" DLP. I HAVE OWNED THE UNIT JUST OVE THREE YEARS. THE UNIT INDICATED THAT THE LAMP NEEDED TO BE REPLACED WHEN THE UNIT WAS TURNED ON. I ORDERED A LAMP AND BEFORE IT CAME IN THE UNIT QUIT WORKING. I REPLACED THE LAMP AND WHEN I POWERED UP THE UNIT I GOT A STEADY YELLOW INDICATION AND THEN A SOLID RED. MITSUBISHI TECH ADVICE STATED THAT I MAY HAVE BEEN SHIPPED A BAD REPLACEMENT LAMP. I SENT THE LAMP BACK AND ANOTHER WAS SENT TO ME. THAT LAMP ALSO GAVE THE SAME RESULTS. I CALLED CHUCKS ELECTRONIC REPAIR AND A VERY KNOWLEDGABLE TECHNICIAN RESPONDED TO MY HOME. IT WAS DISCOVERED THAT THE POWER SUPPLY BOARD WAS BAD AND THAT THE LAMP NEVER NEEDED TO BE REPLACED. I SPOKE WITH REPRESENTATIVES AT MITSUBISHI SEVERAL TIMES AND THIS WAS NEVER EXPLAINED TO BE A POSSIBITLY. THE TECHS AT MITUSBISHI BASICALLY JUST READ FROM THE OWNER MANUEL AND HAD NO IDEA WHAT THEY WERE DOING.
Posted on May 15, 2008
I can not get my tv to turn on. the timer is displaying a green flashing light.
Posted on Jan 27, 2011
After buying two lamps (at a cost of $500.00) we had to call the Mitsubishi service man. He came out at a cost of $150.00 (his appearance fee), and told us right away (after taking out the lamp that we had newly installed) that the socket was smushed/smashed. He then went opened the set from the back and tooled around, and unsmushed/unsmashed the socket. We were so happy. On installing a lamp we all must shine a flashlight into the compartment so that we can see what this lamp is going to connect to. Just like a lightbulb, there is a socket on the left inside of the compartment that the lamp must plug into. From our dark vantage point we could not see this, and with the newly manufactured lamps, which are not the same configuration as the old, it is a very tight fit and this connection socket is vital -- or the set will not work. I wish they would have told us this. That lesson taught to us by the Mitsubishi service person cost us an additional $100. Well anyway, we are sharing it with you. Good luck. Maryland
Posted on Feb 01, 2007
My tv is in stand by mode and can't reset it
Posted on Oct 02, 2010
I am trying to put this lamp back and my tv could someone help me
Posted on Jun 07, 2008
Do you know if it was the top or the bottom of the set that he took off. i have the same problem, and i know that it is the connection and probably the bulb as the bulb went out first but i see that the connection is pushed inand i have to dig it out but cant get to it from front of set.
thanks
Posted on May 06, 2008
We have the tv on a power strip. I turn off the power strip supplying power to tv wait 30 seconds then turn power back on power strip. tv flashes green for 20 seconds more, then works ok.
Posted on Apr 28, 2008
The buttons are menu and device at the same time for 5 sec, then the first set of flashing is digit one of the error code, then the second set of flashing is digit number 2. For example
flash.... flash flash...
would be error code 12
the code repeats itself 5 times and then the light goes off.
Posted on Dec 13, 2007
I have the same problem with my Mitz wd62525. I had a service guy take a look and the lamp is definitely not the issue. It could possibly be the lamp timer reset is not working properly. There is a button combination you have to enter on the front panel of the TV to do this (unfortunately I don't know what it is). If this doesn't work its probably a more technical wiring issue needing a service technician to resolve. Hope this helps. If you find the reset combo - please write back.
Posted on Dec 30, 2006
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 PROBLEM
YOU NEED A FIRMWARE UPGRADE FOR THIS MONITOR.
SERGIO
Mar 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-62525 sound will come on but no picture.
Your tv would turn on if you replace the only two 3300µf@16v capacitors on the power board . You wil notice they are bad by the way they bulge up at the top and may be leaking electrolyte a little from the tops . But the rolling lines would still remain but much less noticable.Then other symptoms will eventually appear. Truth is many many many many other capacitors need to be replaced inside the electrical chassis. Your TV would need to go to a repair shop that is expierienced in that repair because it is so extensive.
Oct 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
Jun 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Dec 10, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
2,528 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
