Question about Canon Cameras
My 17-40 canon lens on a 5d body. i have ISO50 Fstop22 shutter 30sec and i a would think i can lock focus on centre or foreground and gert a sharp result but its not the case. My photos are a bit sharp but not the same as F4 ISO100 where the focus area is smaller but sharp. What am i doping wrong?
  • johnnypixel Nov 18, 2008
    Thankyou!
    That was spot on!
    I have now found that the canon 5D will handle up to about F16 before it starts difracting.
    my other camera nikon d70 28mm @ F22 iso 200 would be sharp because it was also shooting at 28mm instead of full frame 17mm.
    Turns out that The Zoom distance is a factor for sharpness too.
    I will try my 5D on 17mm @f11 ISO50 and work up from there on the stops.
    Im not too fussy on sharpness but i just want it better than my d70! after all it is a full frame 12.3 megapixel camera.
    Thanks so much for your response it was something I knew nothing about.
    Cheers
    John
    Problem Solver:
  • 12 Answers
The aperture (f/ ) is closed too much and what happens is 'diffraction'
read more about diffraction here:
http://www.luminous-landscape.com/tutorials/understanding-series/u-diffraction.shtml
good day
yitzy
Posted on Nov 18, 2008
How do I get my canon 6d to focus when using my canon zoom lens ef100-400
When you put your camera to M with the main dial, it should not have any effect on the focusing. With M you only can choose your Aperture, Shutter speed and ISO manual. With P, the camera will choose a setting it thinks is the best, but you are allowed to change it like another speed or Aperture setting. The camera will try to compensate with ISO, when you are out of the normal limits.
Just when you put the AF / MF switch on the body, or on the lens to M. the lens hast to be focused by hand.
Feb 28, 2015 | Canon Cameras
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
Will this lens work with a Canon 5d mkii?
Quantaray makes their lenses with a variety of camera mounts. A lens with a Nikon mount, for example, will not work on a Canon body. As long as you get the lens with a Canon mount, it will work with the 5D MKII.
Mar 09, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
All of a sudden, my Canon Rebel SLR stopped focusing and I cannot depress the shutter button when on AF mode. I can press the shutter button on MF mode, but there is no focusing happening. Do you think...
Try this...remove the lens and fire off a few shots. Clean the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol. Re-attach the lens and try it.
Apr 13, 2011 | Canon Digital Rebel XSi Digital Camera
17 to 85 EFS IS lens with issues. Auto focus bounces back and forth and wont lock in. When it does work, Im getting intermittent error message saying that lens and camera body are not communcating.
It has lens communication problem either it can be giving by lens main pcb or diapharm unit.
you can open lens rear cover and clean all main pcb connection with iso lequid or fiber pen and then put it back all things back and try with body if its work then problem is solw
if not then nned to replace main pcb first and try i think it can be solw the problem.
other wise you have to replce lens shutter unit.
Aug 22, 2010 | Canon EF-S 17-85mm f/4-5.6 IS USM for EOS...
Try and fit Canon EFS Lens to EOS 5D Body
As far as I know, you should use L series Lens to fit Full Frame Canon Camera (5D & 1D).
That would be no adapter, but please correct me if I'm wrong.
Jan 13, 2010 | Canon EOS-5D Digital Camera
My Aperture shows 00 in my digital display and no auto focus
aperture 00, that means the body don't identify the lens, or there is no lens. try to see if the lens contacts are in order. Try another lens, par exemple you can go to a shop and try the most beautiful lens you ever seen for free.
Feb 01, 2009 | Canon EOS-5D Digital Camera
Focus problems.
The canon 5d was suspected to produced low sharp pictures, but it's wrong. Sharpness is a parameter on the 5D. You can tune it in the menu/image style/ then you choose your style and hit "jump". The first cursor is sharpeness. Enjoy.
Nov 03, 2008 | Canon EOS-5D Digital Camera
Minolta Dynax 7D I fined it dificult to auto focus using a 100mm macro lens even with a very sharp subject the lens just keeps running in & out I never had a problem with this & wonder is this a...
I don't know if I can help you. But I will try a guess. Some cameras focus on 1 point and it is not necessary the center. Maybe if you give your camera a point to focus on then keeping your fingers half cocked on the shutter shift the focus off-center to however you want to compose it, then click.
But if it was working properly before and then stopped working properly, did you lend your camera to someone, drop it or subject it to impact? I don't think anything is really wrong but I could be wrong. Have you checked the AF/MF button. Could someone may have accidentally pressed it?
If you are using the macro lens, did you check the camera's distance limits? I understand that the 7D actually focuses faster than the Canon EOS and Pentax. Canon and Pentax need to hunt that's why they take longer.
Jul 22, 2008 | Cameras
FOCUS OUT OF WACK...big problems
Hi
Change the mode to 'One Shot'. Press the AF-WB and turn the top dial to 'One Shot'.
2. Increase your depth of field. When shooting in Av try using f11. This should help with te out of focus people on the ends. Check your shutter speed as well. Good rule of thumb is to keep the shutter speed higher than the focal length of the lens. i.e. 100mm lens should have a shuter speed of 100+ for hand held shots. You may need to change the ISO speed to get the shutter speed in low light. Lternative is to use a tripod.
Hope this helps.
Apr 10, 2008 | Canon EOS-5D Digital Camera
Cameras Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
