Question about Dacor ECD230 Epicure Electric Double Oven
Dacor CPS130 Wall Oven
Cannot locate temp limit switch to reset same
4 Suggested Answers
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
abhishek33
  • 1239 Answers
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Posted on Nov 06, 2008
SOURCE: My Dacor wont heat, broil or convection after self cleaning
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Posted on Jan 10, 2011
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
I want to re-set high temperature limit control,
if you open the oven door all the way, then, look under the control panel (where the top of the oven door seats) you will see a plate that has 6 to 8 screws holding it in place.Remove the screws of that plate with a phillips screwdriver.You will possibly need a flashlight to look inside the space where the reset switch is located... but it is THERE. Make SURE that you TURN OFF the circuit breaker or... UNPLUG the range... B4 you proceed to reset. Look for the Red Button on the back side of one of the limit control switches. Press it in till it clicks. (sometimes you'll hear it... sometimes you wont). Plug baack in ro reset your breaker switch, Turn on your oven and see if it works. If it does... then replace the vent plate close your oven door and now your cook"n with gas...well... electricity really.
May 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
I have a KEBI17DBL8 Oven that will not work after using the self clean cycle. Should I get the thermostat replaced or but a new oven?
No, no need to get a thermostat or replace the unit...yet.
sounds like a tripped hi-limit thermo.
that model number looks like a double oven wall unit, correct ? if so, big job. if not awesome. if it is, it's hard only because these are heavy. (alot of techs like myself have "wall oven carts" that allow me to remove it fairly easy) you might not have to pull it out though if it's not a wall oven, my bad.
however, I think it may be the older unit's manufactured by "Dacor". if so the limit switch on most of those ranges is a "non-resetable" style. meaning you'll have to replace the themal cut-out or aka thermal switch.
*FIRST, unplug the unit or shut off the breaker.
the hi-limit is located by the latch/lock assembly, so you'll need to dismantle the unit to a degree. if it's a free standing range, it's pretty easy. lift the top and the latch/lock access panel is located right there.
you'll need to determine the "why" as well of course. did the cooling fan/blower fail (#4173004), or the cooling fan therostat (#4173008) ?
the part number you'll need for the thermal switch failure replacement is #814505. check the old one by ohming it out first of course.
hope that helps,
good luck
Sep 26, 2009 | KitchenAid Ovens
Dacor touchpad
HI, this is a Element relay circuit failure. this relay is a separate PCB board with attached relays.
this relay board will need to be replaced.
CLICK HERE TO ORDER
Jul 19, 2009 | Dacor ECD230 Epicure Electric Double Oven
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dacor Wall Oven won't heat - Cannot find thermal reset switch
Open the oven door and unscrew the vented panel at the top. Make sure the oven is off. Atop the electronics in there you'll see a little red button. Push it. Voila.
Dec 24, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor cps130 wall oven f1 error
Nov 06, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
Jan 07, 2008 | Ovens
Dec 04, 2007 | Ovens
Dacor ECD230 Epicure Electric Double Oven Logo
105 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Jose Pino
Are you a Dacor Oven Expert? Answer questions, earn points and help others
