Question about Koss KS3102 System
Return to factory settings
I didn't have my book after moving and set the program to PAL. How can I get it back to factory settings or North America TV? All I get now is B&W and moving up & down the tv ... impossible to read. Thanks ... Patricia
  • Anonymous Mar 15, 2014
    i have tried setting it back to factory settings but only returns to "dab auto scan...
    f26 dab ddowfic. What shouls i do?
Set it by hitting general...(i know its hard to read) but hit preferances...than scroll back up to the top selection above pal...exit ...it will stop rolling and return to color
Posted on Feb 08, 2007
SOURCE:
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
How do I fix
Reset to Factory Settings
  • 1 Download the computer software for your Western Digital My Book World Edition if you don't have it installed on your computer. The software can be downloaded on the Western Digital website (see Resources.) Install the software to your computer.
  • 2 Go to the "Start" menu. Click "All Programs," the "Western Digital" folder and then "My Book World Edition Software" to launch the software.
  • 3 Switch to the "System" tab. Click either the "Restore Configuration" or "Full Restore" button on the tab, depending on your My Book World Edition drive.
  • 4 Click the "Browse" button, select the factory settings default restoration point, and then "General Restore" to return the unit to factory settings, or click "Full Restore" and then "Restore Factory Default," again depending on your specific My Book World Edition device. The unit powers off, all data is erased from the hard drive and the My Book is returned to factory settings.
Jan 14, 2015 | Western Digital 1TB My BOOK ELITE USB...
Hxct16e
This is all I can find, might do the trick;
When changing the multiplexer to NTSC or PAL all other settings
are returned to the factory defaults.
The multiplexer can be used with either NTSC or PAL systems.
To set it up for NTSC operation:
1) Turn off the power
2) Press and hold the and {M} buttons.
3) Turn on the power
To set up the multiplexer for PAL operation:
2) Press and hold the and buttons.
Password Code User1 (1111)
User2 (2222)
User3 (3333)
User4 (4444)
Supervisor (5555)
Apr 03, 2014 | Honeywell Hxct16e 16 Channel Color...
Reset wd my passport
If this is western digital world edition
The software can be downloaded on the Western Digital website.
http://support.wdc.com/product/download.asp?groupid=118&lang=en
Hope this helps
Nov 04, 2012 | Computers & Internet
How to reset Pandigital 7 in. Planet Tablet to factory settings?
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Oct 17, 2011 | PANDIGITAL Digital Book 843967071153...
The picture is only black and white and is flashing on my computer screen. Sound is good.
Usually, this indicates that video source is PAL but the capture is set to NTSC, or that the video source is NTSC but the source is PAL.
Make sure that the video capture device is set to match the signal of the input.
PAL is used in Europe, NTSC in North America.
How you set it depends on the Video Capture software you use, but look for PAL/NTSC setting and switch it.
Apr 18, 2011 | Diamond Multimedia ( VC500) Video Capture
I use my sansa clip for audio books.
Reset All
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop.
-Tha Mp3 Doctor
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
Rolling picture
try unplugging everything take out your hardrive then plug the stuff back in
Apr 20, 2008 | Microsoft Xbox 360 Console
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
Oct 04, 2017 | Oritron Televison & Video
Koss KS3102 System Logo
134 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
