Question about Dell 3100cn Laser Printer
Need feed rollers for dell 3100cn laser printer
I need the one behind the main pick up roller in tray 1
Soulvisitor
  • 1113 Answers
SOURCE: Pickup Roller not turning for upper tray
I think it is not a problem with the parts you mention, I think it may be that the printer is not getting told to feed from manual bypass tray (tray1) (ie driver setting)
what software are you using, is driver correct, what operating system, what are you tring to feed from bypass just standard?
I have fixed hundreds of these and the parts you mention I doubt is the fix
There are options on how this tray behaves available, in driver
tell me more and I'll help you
Posted on Nov 30, 2007
  • 3 Answers
SOURCE: Dell 5100cn Paper Tray Won't Feed
i think you need to look your pc maybe something wrong inside your pc..try to do something for your dell..
Posted on Jan 19, 2009
SOURCE: FEEDING PROBLEMS FROM PAPER TRAY
Brother MFC7820N Paper Feeding Kits are available at Precision Roller:
http://www.precisionroller.com/brother-mfc7820n/products.html
$25.75
Paper Feeding Kit - Kit contains: Pickup Roller Assembly, Separation Pad - Genuine Brother Kit
For Use In: Brother MFC7820N
and also Brother DCP7020, Brother HL2030, Brother HL2040, Brother HL2070N, Brother intelliFAX 2820, Brother intelliFAX 2920, Brother MFC7420
Mfr Part #: LM6291001, LM4581001
PR Order #: E0823
Annette G
Posted on May 18, 2009
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 27 Answers
SOURCE: hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Posted on Aug 10, 2009
Paper Jam Fuser 077-104
Most likely you will have to replace the fuser. Also I would inspect all pick up rollers and make sure they are all textured with no smooth or bald spots. Bad rollers are the #1 cause of jams. Also if you hear any clicking you may have a bad gear.
Jul 13, 2012 | Dell 3100cn Laser Printer
My samsung printer is not picking up the sheets of paper correctly and they seem to be sticking on the roller
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
Feb 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
When sending to print the machines makes noise as if it;s grindin
hi that is a paper jam..this happens coz the rollers in the paper feed tray are not functioning well...try cleaning the paper rollers..
Apr 04, 2009 | Dell 3100cn Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
The printer message says: load paper tray and it is already load
Something to try, The paper (roller) may be slipping on the paper giving false reading of Load paper tray. UNPLUG THE PRINTER FROM MAINS and CLEAN the (roller) as best you can with quick drying solution, Tape cleaner or Similar. Good luck Bob.
Mar 18, 2009 | Dell 3100cn Laser Printer
Will not feed from manual tray
Did you go into the control panel menu and verify that it is set to pick up from the manual tray?
There are 2 things that control that roller. One is the motor and the other is the logic board which gives the signal to the motor that controls the take up roller.Since the movement of the roller appears to be normal,the logic board may be at fault. Unfortunately I do not have the service manual on this model. In any case, you would need service on the unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 19, 2008 | Dell 3100cn Laser Printer
3100cn not printing
with the access door for the paper open, slide the paper in, try to print. If the feed roller turns but does not pick up paper then the feed roller is worn beyond use and must be replaced.
Sep 23, 2008 | Dell 3100cn Laser Printer
Paper not picking from tray 1
More then likely the paper feed rollers are worn. These rollers are replaceable, and are also included in the maintenance kit.
Jun 23, 2008 | Dell 5110cn Laser Printer
Paper Jam
We need to the model/make to help you
but using some detective skills I've decided you are using a HP machine
Yup Dirty damaged worn feed roller but what model machine is it they are all different but pull out tray 2 cassette all the way and look in, there is probally a cylinder like rubber roller 5cm wide front centre of where cassette slides in, there might be roller on the cassette too at the front center as well.
Most modern printers feed rollers just slide off after lifting small plastic tabs on them and gently pulling, feed rollers are available but you can sometimes also get results by cleaning them with a dash of metho or water on a rag.
If paper feeds 2wo sheets at once then you need to change the seperation pad/roller too.
Nov 01, 2007 | Dell W5300N Laser Printer
Dell 3100cn Laser Printer Logo
162 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
