Question about Tappan Kitchen Ranges
Heating elements won't work
I just bought a Tappan stove. Hooked it up, the clock works but the burners won't work or the oven won't work. What is going on? I can't figure it out
  • melissauffor Nov 19, 2008
    Thank you. It was connected to a 20 amp breaker instead of a 40 amp breaker. Thanks for your help.
  • 5,911 Answers
If this is an electric range, double check your voltage at the receptacle. It should read 220-240VAC. It sounds like you could be missing one leg of the 220 service. This means, you may only have 110-120VAC coming from your receptacle. The clock will still work because it only uses 110-120 VAC to operate. The burners, however, require the full 220 service to operate. The following link explains how the receptacle should be wired and the voltage requirements:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I know the link is for converting power cords, but it gives the information of how the receptacles are wired and the color codes for the wiring. The two "HOT" leads at the receptacle are the larger slots. A reading across these two slots (RED and BLACK wires) should read your source voltage.
I hope this may help you. If your range is NOT electric, please post back and let me know, so I can assist you further.
Posted on Nov 18, 2008
How do I troubleshoot oven not heating in a Tappan TEF361ESD?
You can test the element by unplugging the machine, removing the back wall to gain access to the bake element at the bottm, and using a volt meter check it for continuity. There is also a thermal cutoff that you want to check while behind the machine.
Jun 01, 2012 | Kitchen Ranges
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
My stove does not work
Sounds like you have a voltage problem. try slamming your double 40 amp house breaker on and off 2 times. then try your stove out and see if that worked:)
Mar 12, 2010 | Kitchen Ranges
My Tappan stove oven bottom heating element is not working. How do I fix it?
The element is probably bad. Remove element after unplugging stove and check with ohm meter. If you do not have one take element with you to parts store and they will check for you. Good luck. Hope this helps.
Mar 09, 2010 | Tappan TEF242 Electric Kitchen Range
Burners and oven will not heat
Something is stopping the gas flow. Turn off gas. Disconnect line from the stove have someone turn on and off the the gas just for a second.(make sure no flame in room). See if gas is available.If not it is the gas line leading into the house somewhere,not the stove.  Follow the piping to the first thng it comes to. Disconnect that line and see if it is open from there back to the connection. If you finally get to the valve,which I dont think you will . You will have to disassemble  or replace it.
Dec 10, 2008 | Tappan 30IN ELEC IGNa Oven
Burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Apr 23, 2008 | Kitchen Ranges
Tappan oven won't turn on after cleaning
I don't precisely understand...responding. I assume that if you say oven on that the oven isn't heating but the indicator controls are working. This has several possibilities. First, do turn your circuit breakers off then on...there are two linked together. This may reset something. If that fails, your problems are likely in either the high limit safety switch or the heating elements. The elements are more likely. To check them, turn off the power and remove them from the oven. This is usually by taking out one screw and unclipping the element. See if the element is bulged or damaged. If not, use a multitester to see if one of them is not conducting. Replace it. High limit should conduct fully. Use the curcuit diagram on the stove to determine its location.
Dec 27, 2007 | Ovens
Kitchen Ranges Logo
147 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
