Won't turn on
I have everything hooked up to to my K7V Dragon plus motherboard and it won't turn on there is power to the board and i know where it supposed to be pluged into (i think) so if u can send me a pic of how it is to be put back together or if u can descripe it please get back to me
  • 22 Answers
Hello czbad92
Did you try to unplug everything on the motherboard, and reseat the cmos battery. Then plug in everything.
Let me know if that works
Thanks
Agent Hughes
Posted on Nov 18, 2008
What does three long beeps soyo sy-p4vgm indicate? Everything was running well. Powered down, powered up..beeps thanks
might be a faulty connection/lead make sure they have secure connections
test all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive also cd/dvd/3.1/2 inch floppy drive leads
hope this helps
Sep 30, 2010 | Soyo SY-K7V Dragon Motherboard
Soyo k7v dragon plus motherboard continuous
2 beeps = memory problems. Since you get them even after the memory has been replaced then the problem is in the motherboard itself. Check the capacitors for bulging. If you can't find ones or you can't replace them then the motherboard is dead.
May 13, 2010 | Soyo SY-K7V Dragon Motherboard
Hi Jopav1,
At the age of *********** board, I would recommend physically looking at the board, in particular, the large upright capacitors. If the tops are bulging, or have anything leaking out of them, send the board to a recycler, and look for an exact replacement on the used market, or replace with new. I just bought the same board you have today for $25, with AMD 1800 CPU.
At 10 years of age, the battery is probably past due for replacement too. It is a standard CR2032 3Volt battery. If you replace it quickly, you may not loose your BIOS settings.
If you have a volt meter, you can check your power supply voltages. Again, your manual will show what voltages to expect at each power connector pin. A range of +/- .05V is generally allowable on all sources.
Also try unplugging all boards and powering it up. The beep should change to a sequence of 2-1-3-1 beeps, indicating that it's not able to see the video card. If you still only get a repeated long beep, It's possible that the CPU itself may have died. These are also available very cheap at this point. The fact that you are getting a cycling beep indicates to me that the CPU is OK though.
I looked up beep patterns and did not find anything for one long repeating beep for the Phoenix BIOS on your board. There is no mention of them in the Soyo manual either.
Last resort is resetting your BIOS settings to "First Birthday", and try again. This will require you to re-set any manual settings you had set previously (probably 10 years ago). This is done by moving the jumper located between the green LED, and the battery, to the two pins nearest the LED, for a second, and then back to the position nearest the battery.
Good luck
Video Flyer
Mar 22, 2010 | Soyo SY-K7V Dragon Motherboard
Where can I get a manual for my KT600 DRAGON PLUS V2.0
I have a PDF file for SOYO KT-600 Dragon Plus V2.0. I can email it to you.
Oct 15, 2009 | Soyo SY-K7V (SY-K7VKPE) Motherboard
SY-K7V DRAGON Plus no longer boots.
Try reseating the memory and restarting the PC. If that doesn't help and you have multiple sticks, try removing all but one, then cycle through to see if maybe you have a bad stick somewhere.
Jun 28, 2009 | Soyo Computers & Internet
K7V Dragon Plus motherboard
check front switch jumpers, often if the power switch jumper is on the reset pins on the board will do this, otherwise check power supply, change it if it still does it i would say the power management on the board (ACPI) is corrupt or failed
Feb 28, 2008 | Computers & Internet
Wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
Computers & Internet Logo
313 people viewed this question
Alun Cox
David Payne
David Payne
