Question about Dell Dimension 8400 power supply ** FREE ** (D8400SATA300W24PINB) Power Supply
Hard drive my computer doesn't boot b/c the hard drive isn't found. how do i fix that?
Make sure your jumpers on your hard drive are properly set. Also, test another cable to rule out that your IDE cable hasn't faulted. You can also go into your bios settings on startup and check to make your hard drive is detected, if not run the auto detection and see if it is seen then.
Posted on Nov 19, 2008
How can I tell if a power surge hit my laptop and ruined it? I can't even get it to boot up
It could either be that the motherboard is fried or the Hard drive has just gotten slightly corrupted. If you have the Windows install disk that came with it you could boot that up and then go into repair mode (press R) and then run "chkdsk /r" this would fix a hard drive issue. However if your laptop will not turn on at all when you press the power button then it is likely dead.
Nov 07, 2012 | Computers & Internet
How to fix no boot device on emachines e442 for free
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 09, 2012 | eMachines E442 E442-v133 15.6" Notebook...
System not found
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 09, 2012 | Sony VGN-NR160E/S PC Notebook
How do i fix my laptop when it says no hard disc is found
Jul 02, 2012 | Toshiba Computers & Internet
I have an acer aspire 5040 laptop and when I switch it on it doesn't go to windows it comes up a black screen saying operating system not found. I have tried pressing alt and f10 but nothing happend. I...
The laptop cannot find the operating system on the hard disk.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 07, 2012 | Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Operating system not found
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.The hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Feb 02, 2012 | Microsoft Computers & Internet
Monitor to other cpu and it works fine. Tried recovery tools and rcovery disc but receive errors, boot from cd rom no emulation, and no hard drive found. Help!!!!
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 19, 2012 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Boot Device is not found
When getting Boot Device not found, it means that:
Hard Disk with installed OS is not selected in CMOS Setup as primary HD or the Hard Disk it self is damaged and can no longer be detected.
Aug 02, 2011 | Compaq Presario 700 470024-192 Notebook
When i turn it on it shows no operating system not found
boot record has been corrupted, or the hard drive is toast!....problem is that you have no cd/dvd rom so you cant insert a restore disk....if you wanted to test it yourself you would have to learn to boot from USB(flashdrive)....unless you have a external USB dvd that you can hook up to it to attemot to rebuild the boot record!
Jul 17, 2011 | Dell Inspiron Mini 9 Notebook
Computers & Internet Logo
49 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
