Question about NAD C320 2-Channel Amplifier
PreAmp to Amp problem
Connected up a NAD preamp to my NAD integrated amplifier. OOps - now the CD player doesn't work through the CD input - but works at full blast through the Main input (PreampOut/Main In)
have i gone and short-circuited the pre-amp in my integrated amp?
any suggestions - can't think of anything else
Sorted it. You have to put the plugs back in the PreampOUt/Main in or it cuts out the pre-amp.
Posted on Nov 19, 2008
Is an unidentified player compatible with an NAD integrated amp which has analog inputs?
As long as the "player" has phono connections you should have no problems with compatibility.
Jan 23, 2016 | NAD Audio Players & Recorders
What kind of pre amp do i need to operate my parasound HCA-2205A high current power amp
Any preamp should work. A preamp goes into your system between the amp and the other components which plug into it- CD player, FM tuner, Turntable.....etc. It's takes their output signal, processes it as my be Volume, bass, treble... and then send a sufficient signal to the amp to drive the amp to power your speakers. As long as the preamp output is enough for your Amps input any will work as most will be.
Nov 02, 2014 | Audio Players & Recorders
Sorry, new at this and finding the manual hard to understand, how do I connect my nad C-340 amp to my C-162 preamp. Trying to add a turntable and have a few other questions
You must connect the turntable to the plugs on the left side of your amplifier when you are behind the pre amp. You have to know if you are using a MC or a MM element in your turntable and connect to the right plugs. Don't forget to put the switch in the right position (also MC or MM) The moving coil element is giving a very low voltage accordingly to the Moving magnet element. So it needs some extra amplification.
Nov 28, 2012 | NAD C162 Amplifier
Cant get no sound from my Nad C162 pre amp connected to my C272 power amp , and ideas please?
First prove if it's a preamp problem or an amp problem. Plug one of your sources directly into the amp for a moment and play something VERY LOW in volume. If the amp is ok it will play VERY LOUDLY.
If so, look at the preamp and make sure it's not muted or a tape is selected.
Apr 03, 2011 | NAD C162 Amplifier
How do I connect a Mirage Omni s-10 Sub Woofer and a Parasound Model 2100 Pre Amp to the NAD C372 Amplifier?
You DO realize the preamp is duplicating stuff in the Nad C372, right? This Preamps adds nothing but PHONO connectivity and control. That's why they're called "preamps".
Register and download the manual for free at
Model 2100 Picture and article:
Use the Sub Out pair on the Preamp (joined by an RCA Y-cable) for the Sub Input on the sub (duh):
Run RCA from the Preamp Main Out to the C372 Aux In to hear any sources attached to the preamp.
Or, if you don't NEED the preamp because you don't have a turntable,ditch the preamp and connect the sub using the speaker outputs on the NADS, according to the manual.
Mar 08, 2011 | NAD C372 Amplifier
Hav nad 2100. I dont understand what the lab in post are for?
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used.
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use them UNLESS you have a turntable source.
Feb 23, 2011 | NAD C325BEE Amplifier
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
NAD T760
You should connect the RCA connectors from your turntable into the phono input of the preamp. Also, make sure you have the grounding wire from the TT connected to the grounding on the preamp (if you do not have a grounding point, then just connect it to one of the screws on the preamp). Then connect the output from the preamp to either the Tape or the CD points on the T760. On the front panel press tape monitor and you're done.
Check and let me know how it goes. My set up's working fine except for clarity, which still needs to be perfected. I'm using a normal step-up phono stage.
Regs/ Avinash
Mar 29, 2008 | NAD T760
RCA Problem
You need an active subwoofer input in your amplifier.Which amplifier you are using? Only latest pioneer amplifiers has active sub input and sub output which can be connected to subwoofer.If you dont have active input then you will have to connect it the way you did in old player.
Feb 10, 2007 | Pioneer DEH-1800 CD Player
NAD C320 2-Channel Amplifier Logo
246 people viewed this question
Top NAD Audio Players & Recorders Experts
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
