Question about Maytag MZD2669KE Side by Side Refrigerator
Leak from icemaker shorts electricity in house
Ice maker leaks on 5 yr old side by side fridge freezer but I dont know why. Ice seems to be made in normal way. Water dispenses OK from door. But the gulley in the bottom of ice bin freezes solid so the auger wont turn and hence trips out the electicity in the house. Water also leaks down back wall of freezer and freezes in little rivers. Invades the fan and causes it to stop working. Water tube is NOT blocked and in any case was replaced with one with an air slot to prevent freezing in the tube. I need to stop the block of ice from forming in the bin, stopping the auger motor and I need to stop the leak down the back of the freezer. I cant live without electricity in the house!
  • 1 more comment
  • tasker Feb 24, 2008
    Ice cubes melt in the left rear corner of the ice cube bin. They subsequently freeze into an ever larger clump of ice. The ice maker works correctly. I have checked the bin just after the ice maker has dropped new cubes and refilled with water and see no evidence that the ice maker is leaking. The freezer temperature never gets above zero degrees. The freezer light goes off when the door closes.
  • Anonymous Mar 30, 2014
    ice maker bin freezing up and auger won't turn
  • Anonymous Mar 31, 2014
    I need to replace the tube that runs from the wall to my fridge due to a crack in the line that's causing a leak. However the replacement part has been discontinued. It has a normal fitting on one end, but connects to a tray under the fridge that holds the water filter. It's a kitchenaid side-by-side frige.
  • 237 Answers
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Posted on Dec 11, 2006
Kenmore 795 leaking water behind ice maker
I would first check the hose that brings the water from the pipes in the house up into the icemaker make sure that's not leaking. Then I would check all of your connections, Making sure they are good and tight and that there's no holes either in the copper line or the poly plastic line. If all of that checks out fine and you have no leaks there then I would investigate the icemaker.
May 27, 2018 | Kenmore Refrigerators
Regulating Temps on Whirlpool Side by Side
well i think you know what this is!!!!
you moved it and it got upset about it?
but some freezers need to be dead upright
or,,,its the darn thermostat's there playing you up like mad if you cant control them there on there way out
best bet is have new ones fitted or just dump it all together,,after all think of how much that floor is worth? and how much ice cream do you need????
ps,,,i use a hammer drill to get my ice cream out the tub?? have you ever tryed "fried ice cream" its realy
"""""yucky"""""??? (sorry im mad you see)
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Maytag MZD2669KE Side by Side Refrigerator Logo
428 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
