Question about Hotpoint RGB745 Gas Kitchen Range
When we cook in the oven it says F2 every 10 mins.
When we start cooking arter about 10min. it goes beep beep beep and F2 come up and it shuts off then it says it every 5 mins. then evry 2mins. then wwe have to wite 15 mins. to turn the oven abck on.
  • 370 Answers
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Posted on Nov 21, 2008
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Need instructions on cooking times for steaming veg
On a 1000 watt oven, I find 7min about right for most vegetables. Those which need more cooking may require 10min or more.
Apr 14, 2013 | Pyrex Pyroflam Steamer Set, 2L
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
When the microwave is finished cooking how can I change the beeping so it only goes off once instead of4 times? That drives me crazy and is so annoying. Thanks, Susan
Hi, you cannot change how the microwave oven beeps after it cooking. You can confirm this by going through the user manual yourself....
May 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I can't enter a specific cook time. only goes 1 - 6 minute. the express cooking times
hit power then select the power setting you want to use 1-10 then enter the specific amount of time you want your food cooked for up to 99 min. then hit start you should be good to go =)
Jan 23, 2011 | Cuisinart CMW-100 Microwave Oven
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Help please
Are you saying that it will stop cooking after 59 seconds, but it will resume cooking if you press Start again?
(If not, please reply back and clarify)
If so, this is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Aug 04, 2008 | Microwave Ovens
Hotpoint RGB745 Gas Kitchen Range Logo
606 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
