Question about Sanyo Refrigerators
I have a Sanyo kegerator that will not cool enough. I have set the thermostat as cold as it will go and it will only go down to about 42 degrees. What can I look for?
Drop thae stat it's a screw on the left side that controls temp.Don't rush this you don't wnt to freeze your beer. 1,5 turns to the left will take you down to ice cold beer.
Posted on May 09, 2009
Cooling issues
sounds like the thermostat. can you bypass it (ie connect the two wires together) and make it run all the time? If so, replace the thermostat
Apr 22, 2014 | Nostalgia Electrics Kegerator Beer Fridge
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
Dec 31, 2012 | True Direct Draw Systems: Kegerator...
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Avanti bd6000
Did you ever find an answer? I have the same problem.
Dec 15, 2008 | Avanti BD6000 Stainless Steel
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
My GErefrigerator does not seem to be cooling as before. I turned up the temperature control from 5 to 7 and also the freezer control higher, but it still doesn't seem to be cold enough. I don't want to...
Hi eapiano,
I'm Harvey th Master Plumber.
Your question is: Your GErefrigerator does not seem to be cooling as before. You turned up the temperature control from 5 to 7 and also the freezer control higher, but it still doesn't seem to be cold enough. You don't want to lose all your food especially in the freezer What can you do? The model number is: TFX22PRX
First, make sure the power is on. Then listen for the compressor motor. If you don't hear it then you have a compressor failure or an electrical failure inside. If you can then look to a bad thermostat. In the mean time get everything into coolers or neighbor"s fridg.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | GE Refrigerators
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Refrigerators Logo
431 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
