Question about OKI C5200n Laser Printer
Copy comes out folded like an accordion and causes jam
The paper comes out in a multiple fold (accordion) and jams the machine. I have replaced the fuser, and it still occurs.
  • 1 more comment
  • lburleson Dec 08, 2008
    I cannot find any scraps of paper anywhere, but I could be missing something. I do know that someone ran cardstock through it withoutchanging the settings. If that caused it, is it fixable?
  • Jeff Hughes May 11, 2010
    Something is either blocking the path or you have 2 bad fusers.
    Make the the bottom roller of both fusers can turn somewhat freely.
    While rotating rollers make sure they are clean.
    Clean all rollers with alcohol swab.
    The fact that cardstock ran through w/o setting change is not an issue.
    what kind of paper?
    what printer driver setting are you using for Weight?
    Any small paper scraps in paper path?
IB4G2008
  • 3587 Answers
SOURCE: Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Posted on Mar 08, 2008
SOURCE: 381 Paper Jam Error
I had to remove every toner cartridge and drum. I found the paper under the second to last drum.
Posted on May 22, 2008
  • 2072 Answers
SOURCE: Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Posted on Aug 31, 2008
crayzeetrayn
  • 837 Answers
SOURCE: HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Posted on Mar 13, 2009
SOURCE: OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Posted on Apr 04, 2009
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
Jamming from all trays, all paper types. Accordion-type paper jamming taking place right behind bypass tray (section C on printer diagram).
The accordion folds indicate all the types of paper are striking something beyond the feed point. There is probably a scrap of paper stuck in the machine, no doubt out of sight and hard to find. If you are able to locate and remove the obstruction, operation should be back to normal
Dec 20, 2012 | Ricoh MPC4000
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
Why does the paper come out wrinkled from HP Laser jet 3030
Problem: Paper jams as it exits printer, starts out as intermittent and gets progressively worse. Paper has accordion folds at bottom.
Cause: Fuser drives paper out faster than the worn out exit rollers can push it out of the printer. This causes the paper to fold up.
Solution: The rubber treads in the rollers wears down, making them smooth. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable. If problems persist, the rollers need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | HP Office Equipment & Supplies
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
Mar 13, 2009 | HP LaserJet 4M Printer
Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Nov 24, 2008 | Office Equipment & Supplies
Konica Minolta Di251
Could be that it is printing a legal print on letter paper. This causes a timing error which appears as a jam. If it is accordion folding behind the exit rollers the paper could be hanging on the exit sensor flag. If it accordian folds in the fuser then the fuser needs replacing.
Jan 04, 2008 | Konica Minolta DiALTA Di200 Copier
OKI C5200n Laser Printer Logo
63 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
