Question about Xerox CopyCentre C20 Black and White Copier
Xerox C 20 photocopier 'scanner blocked' eror message
Unable to determine what this means and how to overcome it
  • tony175 Nov 25, 2008
    Very good solution. Worked well.
    Thanks
    President:
  • 2,072 Answers
There is a scanner lock located on the bottom of the scanner. Look where you take your copies out of the machine. On the under side of the scanner you will see a green latch about an inch and a half long and half inch wide.
Turn the machine off. push the scanner latch inward , then pull it back toward yourself until you hear and feel it snap into place. Then turn the machine back on. that should do it.
Posted on Nov 19, 2008
Hello! I have this message on my printer: "eror relating to PDL emulation problems occur. 016-720". What this mean?
Dell and Xerox printers reportedly have this error. What model printer is it?
Example of Xerox:
https://forum.support.xerox.com/t5/Printing/WorkCentre-7435-Error-codes-116-324-amp-016-720/td-p/8240
Jun 28, 2018 | Office Equipment & Supplies
Xerox C 20 photocopier 'scanner blocked' error message, what can i do?
Try to check green lock under the scanner on the side where your copies went out from copier. maybe you accidentally lock the scanner while trying to get copies.
Hope it helps
Feb 15, 2011 | Xerox CopyCentre C20 Black and White...
I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Photocopier iR2016J is showing an eror message -system error E007
that mean ur coopier fuser flim is damaged. if ur fuser flim damaged in right side corner replace new one.
Feb 09, 2010 | Office Equipment & Supplies
I have a canon xerox machine model 3020 copy is not comming,blank white paper is comming
Canon 3020 is a scanner, not a copier. It can scan a document & store. If you print the image, you will get a 'photocopy'.
S. Mohan
Sep 18, 2009 | Canon DR 3020 Path-Through Scanner
Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Sep 21, 2008 | Xerox WorkCentre M118 Black and White...
Ricoh Aficio 1018 photocopier
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
I get an error message 2019 and unable to connect to twain device
Make sure that your scanner cable is not tightened too much. I had this challenge and found that by simply loosening the cable connection, this error message dissappeared.
Sep 16, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox CopyCentre C20 Black and White Copier Logo
694 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
