Question about Xerox WorkCentre M118 Black and White Copier
Xerox WorkCentre M118- media tray size wrong
Our tray 1 the top/bottom adjustment isn't centered, so the machine is not reading the right size paper (ie 8x11 paper is read as A4).
can I over ride the size choice, or (better) how can I take apart the tray to re-center it so it is correct?
  • PeterDragon Nov 19, 2008
    I found where the screw was under the metal plate, removed the gear, and re-alligned it.
    so far it seems to have fixed it.
    of course it took me 15 minutes to figure out how to remove metal plate.
    President:
  • 2,072 Answers
Most likely you will have to replace the tray. There is a problem with those trays. Even when you have them set correct they mis read.
You can try twisting it, but they mis shape pretty easily.
Posted on Nov 19, 2008
  • Rick Kasper Nov 19, 2008
    Good. more times than not those trays just cant be adjusted. What you want to watch for also it the paper size not being sensed. The indicator for the paper tray will just be blank and it is the finger in back not hitting the size sensing switches.
    The 118 is a very good machine, but the size sensing and the sturdiness of the paper trays is suspect.
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Trying to change paper size from A4 to 8.5x11 on a Xerox Workcentre M123
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
Jul 22, 2010 | Xerox WorkCentre M123 Copier
M20/Ms0i WorkCentre display "Paper Size Mismatch"
the settings on the print driver and the machine do not match.
  1. ress the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required paper tray is displayed; either [Tray 1 Size], [Tray 2 Size], or [Bypass Size].
  4. Press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until the paper size loaded in the paper tray is displayed.
  6. Press the [Enter] button to save the setting.
  7. Press the [Stop] button to return to the Standby mode.
Jan 28, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox workcentre M118 is having problem in pulling the paper to the fused roll.. what could be the problem?
Most likely one of the rollers in the paper path between the developer and the fuser is slipping. You are going to have to get a Xerox tech to take a look at it.
Sep 10, 2009 | Xerox WorkCentre M118 Black and White...
Tray guides aren't aligned in Xerox WorkCentre 7665
What is the model number of your machine? If it is a 118, 123/128/133 the paper tray most likely will have to be replaced. But it would really help to know the exact model number. You may have to change the size in the machine memory, which is also different per models.
Mar 17, 2009 | Xerox Office Equipment & Supplies
Paper Tray won't read
That is a paper tray issue with that machine.
The tabs that are supposed to actuate the switches on the back of the tray either twist or get out of position.
You can try sliding the paper guides around, but more than likely the tray will need to be replaced.
Common problem on the 118
Jan 19, 2009 | Xerox WorkCentre M118 Black and White...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Xerox WorkCentre M118 Black and White Copier Logo
201 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
