Question about kawasaki 19.2V 4 Piece Cordless Tool Kit
Ball bearings fell out of the area where the ''chuck'' is attache
RE: Kawasaki 19.2V DrillI was putting in flooring screws (#9s X 11/4") when I noticed small ball bearings falling out the space between the "chuck" and the drill.My drill was purchased at Cosco for Christmas last year and I am otherwiswe very pleased with it. Who may I contact for warranty repair?Thanks Tom V from Old Fields
  • 25 Answers
Call Alltrade Tools customer service so they can provide you with a replacement drill. Call 1-800-423-3598, give them your model number for a replacement.
Per "Ask Carl" of Alltrade
Posted on Nov 27, 2008
Put a ball bearing back in a high pressure oil pump
If it fell out then it can't do it's job which is to regulate the pressure within the pump and is "shot."
Aug 27, 2012 | Ford Cars & Trucks
You have lost the little steel ball that actually seals the bleed hole. The screw itself does not seal. When screwed tight, the bleed screw pushes on a little ball (looks like a ball bearing) that blocks and seals the hole. This ball is very small, and it likely fell out when you removed the screw. Hope this helps.
Nov 29, 2010 | 1997 Plymouth Neon
Removal of chuck
Harold, Have you tried looking from the top? Maybe you can put a rod into the spindle from the top and give it a tap. Al Kupchella
Apr 10, 2010 | Turner Walker-turner Rockwell 20 Inch...
How to replace the chuck on a hilti te10
The complete chuck is not easily replaced. It you stick an SDS+ bit in the chuck and it seems to fit tight without much wiggle then the chuck can be replaced without taking the tool apart. The rubber cap on the end will just pull off. Next the locking collar with the annular spring will come off with the out side sleeve. Underneath is the guide tube with two enlongated rollers. The locking collar should have a ball bearing underneath it that locks the sleeve in place. Usually the roller bearings or ball bearing are missing.
Mar 14, 2010 | Hilti Drills
Ball bearings on bottom drawer assembly fell out. Can't figure out how to put it back together.
If the ball bearings fell out, you have to put them back in one half at a time. The thing that houses it is half the size of the length, so put the top one in at the left and the bottom one in at the right and then you can push them together once they're in.
Sep 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
10-32x1 Left Hand Chuck Screw for Milwaukee Magnum Holeshooter
any reversible drill will have the lh screw in the chuck
cruise the garage sales, dump shops etc and get a dead drill and remove the screw
could be phillips head or hex head but that will not matter
if you have access to a quality bolt retailer ( not a hardware shop) they will have the screw
go to an appliance repair shop that repairs drills as they may have a dead drill with the chuck still attached
Apr 04, 2017 | Milwaukee Drills
I'm not familiar with that brand, but it sounds like your chuck just fell apart.
It can be reassembled, but a better and more long lasting fix would be to get a replacement chuck and swap them out. This will save you what could turn into hours of frustration, attempting to repair the old chuck only to find it still doesn't spin freely or tighten correctly.
Note the numbers on the side of the chuck itself, as well as the tool make and model #. There's no need to replace it with the same brand, but what is essential is that you find the correct chuck mount for your drill. (This is usually a number code like 2JT, 3JT, etc.) If this is not marked on the chuck, you'll have to know the diameter and thread pitch of the shaft the chuck screws onto.
Other than that, you merely need to decide the capacity (size drill bit allowed) of the chuck you wish to put on your drill.
Do a web search about drill chucks and you can find many suppliers that will be happy to sell you a new one, and you'll soon be drilling with the best of them...
Hope you find this helpful! If so, please take the time to rate this post.
Mar 25, 2009 | Drills
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
136 people viewed this question
Top kawasaki Drills Experts
Jim London
Jim London
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
