Question about GE WBSR3140DW Top Load Washer
Agitator is weak
Durring the wash cycle, I can reach in and stop the agitator from doing anything.
  • 1,543 Answers
I take it the motor was still running and you could stop the agitator. Pull the agitator off by pulling it straight up. Sometimes you need to slip a belt or similar object under it and attach the other end to a handle to allow you to pull with more force. Now, take the one bolt off and remove the plastic upside down can shaped agitator drive. If it cannot be pulled off, you will have to break it (use a hammer and chisel). Now, if you can turn the splined metal shaft with your finger, you have a bad transmission, but more likely you will not be able to turn it with your fingers, which means all you have to do is replace the agitator drive WH49X10042.
Posted on Nov 19, 2008
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Water will drain durring spin cycle
    This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
    Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
    I have a 2004 whirlpool gold super capacity plus and It is not agitating durring the wash or spining durring the rinse cycle? You can hear the moter spinning, but it is spinning nothing?
    If this is a top load washer, there is a plastic coulpler between the motor and gearcase, it always strips or breaks, you can go to www.searspartsdirect.com to look at exploded view of the parts for your washer and get the part numbers
    Sep 03, 2010 | Whirlpool Washing Machines
    The machine made a slight squeek noise each time it slowed down and then started up again (durring the wash cycle) We also noticed a strange odor. It was almost a asbestos burning type of smell. Then later...
    It probably mean the spin brake has failed. If everything else is functioning OK and it is not making anymore strange noises it will be OK however when you open the lid(during spin) if it takes more than 10 seconds to stop then the brake should be replaced. If you need anything else please let me know.
    Mar 19, 2010 | Maytag Washing Machines
    Loud banging noise during washing cycle. Sounds like agitator is slipping,then banging. No noise during spinning cycles.
    Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
    This is your Agitator:
    http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
    It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
    Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
    http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
    This part is the most likely cause of the noise.
    Thanks for using FixYa.
    Kelly
    Mar 07, 2010 | GE WBSR3140DW Top Load Washer
    Maytag 6300 won't agitate durring wash cycle
    HI. this is usually caused by a faulty drive assembly(agitator gear components and clutch malfunction).
    I recommend replacing the agitator components by purchasing a Agitator replacement kit. and, replace the clutch assembly as well. this will fix this issue.
    Jun 17, 2009 | Maytag Atlantis MAV6451 Top Load Washer
    GE profile washing machine won't agitate it spins out, drains,
    Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
    Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
    GE Profile washer
    suspect gearcase ask for estimate first..could be more than new washer
    Jul 09, 2008 | Washing Machines
    GE WBSR3140DW Top Load Washer Logo
    53 people viewed this question
    Top GE Washing Machines Experts
    Tim Whalen
    Marvin
    Marvin
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
