Question about Acer Aspire 4315 Notebook
Acer laptop Aspire Model the battery turns hot.
Hi geeks, is it normal for all the laptops battery to turn hot....?? I mean really hot.. You can cook eggs on it!!!
  • Acer Master
  • 32,281 Answers
Laptop batteries do get warm when they are in use or charging but not so hot to cook eggs.
This is dangerous and it could explode and catch fire.There could be a problem with the charging circutry or a faulty battery. Get it checked out.
Posted on Nov 19, 2008
How do you hard boil eggs in this insta pot?
  1. Pour the water into the pot, and place the eggs in a steamer basket if you have one. If you don't, just use the rack that came with your pot.
  2. Close the lid, set for 5 minutes at high pressure.
  3. It will take the cooker approximately 5 minutes to build to pressure and then 5 minutes to cook. I let the pressure naturally reduce for an additional 5 minutes after the cooking cycle completed, and then did a quick pressure release. That's around 15 minutes, total.
  4. Place the hot eggs into cool water to halt the cooking process. You can peel immediately, or wait-- it's up to you. (The first time I did this, I didn't plunge into cool water, and they still peeled very easily. The eggs were just slightly more cooked.)
Mar 15, 2018 | Kitchen Appliances - Others
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Can you freeze cooked peeled boiled eggs?
Hi Keith, apparently its not recommended as the white becomes tough and watery. But I accidentally froze some a while back when I stored them in the fridge (they got pushed right against the back wall overnight!) after defrosting they didn't quite taste like eggs anymore! so rather than waste them I just used them for curried eggs and they were fine in a sandwich!
Trust this helps
Regards Alan
May 26, 2015 | Chef Cooking White Choice Gourmet Egg...
Acer aspire 4339 wont turn on with new battery
That means the laptop is not detecting the battery as authentic or full enough to boot the laptop. Most batteries are now smart batteries, so the battery you bought may be an aftermarket battery not supported by the laptop. Return it and cite the issue.
Mar 03, 2014 | Acer Aspire AS43392618 PC Notebook
Smells like rotten eggs
it is happen to old engine because the oil that escape from the engine(engine cover near the exhaust) when it is got hot it sends bad smell but after how many minutes if it already dried up because of heat it will gone (like frying using the used cooking oil in pan there is a different smell).
Sep 19, 2013 | Mitsubishi Cars & Trucks
I would lkike to know if it is normal for this unit (T1625 ) to run so HOT? the fan is direct out the side and I bet I could cook an egg if i left it sitting there- I have cleaned the fan- but still
your laptop is probably very old or the system is bad
if you have warrenty you can get it serviced for the particular
reason.
if not you can spend a few dollars for it to be serviced.
Aug 25, 2012 | Gateway T-1625 Notebook
I have a compaq c60 laptop. a couple days ago the laptop would turn itself off and when i would to reboot it, it would only last a couple of seconds. i noticed its really hot right above and below the fan...
Hello, well, if the fan is stalled, then it really needs to be replaced as it will still be consuming power and getting HOT...which is really not good for a laptop as there is little natural air flow within the case anyway. Actually, I've seen those sort of laptrays with a built-in fan, and I think they're a really good thing to have, bearing in mind if you're running the laptop on battery then it'll drain the battery quicker! But have one IN ADDITION to a normall fully-functioning laptop, not as a substitute for a failed internal fan. I advise get that fan replaced asap before you cook something vital (and expensive) in the laptop. Kind regards, nicam49
Jul 08, 2011 | Compaq Presario Fan
I have Aspire 5520-5912 Notebook. When I turn on power with battery or ac adaptor, the power just comes and goes, the power button light, power indication light and HD operating indication lights just...
I m also suffering from same problem on aspire 4310. When the problem occurs, I remove the battery for an minute and insert again.... This trick have solved my problem. Try the same trick on your laptop and see that whether it works or not... Otherwise get it serviced....
Thanks...
Jun 30, 2010 | Acer Aspire 5500 5570-2609 Laptop
Aser Aspire 5920 Will Not Switch On
it must b some problem with the RAM......get the ram changed ...den it will work fine
Sep 02, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 4315 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
